How much can you skim off the top of a
ed325i
Post Fri Jan 26, 2007 7:15 pm
2.5 m20 block ?
stonesie
Post Fri Jan 26, 2007 8:00 pm
All depends what you want to do with it, for a general rebuild as little as possible to get it flat (a few thou).
But for a 2.7 conversion i think its a couple of mm depending what head, rods, crank and pistons you use.
how long is a piece of string again? winkeye
ed325i
Post Fri Jan 26, 2007 9:23 pm
I havent measured it yet but is there a max that can be taken off ?
Post Fri Jan 26, 2007 10:42 pm
Whats the standard loss for a 2.7 conversion then?
Post Fri Jan 26, 2007 11:46 pm
there is no standard measurement really, on average it's about 3mm
I'm not sure how much you can take off either, as long as valves and pistons do not hit and it can be timed up properly then who knows!
ed325i
Post Sat Jan 27, 2007 9:28 am
So there are no water/oil ways that can be broken into ?
