Powerflex/control arm/wishbone problem
TouringMatt
Post Fri Jan 26, 2007 6:21 pm
Car failed the MOT on Monday on the NS lower control bush. Brought some Powerflex concentric ones to replace both.
Did them this afternoon, OS went fine, NS one was a PITA, had a right game to get the lollipop to line back up.
Took some pics, looks like the control arm is sitting at a slight angle and is slightly shorter than the OS one - surely this is going to cause wear and maybe failure of the bush?
Cant see any obvious damage under there and has always drove fine. Did notice that the FUBAR'd NS bush was sat over to one side
Any thoughts anyone?
Matt
old_skool
Post Fri Jan 26, 2007 6:55 pm
Sorry Matt, I don't really know what to suggest. I've never seen one like that before. It's difficult to see from the pics but are they the genuine alloy control arms or are they a mix, one steel, one alloy?
The N/S doesn't look right at all. Did you compare the stub length of both of the control arms before you pushed the bushes on? I can understnad that, but not the entry angle of the stub into the bush as per your photo. I would guess that the N/S control arm is bent :x
TouringMatt
Post Fri Jan 26, 2007 7:06 pm
They are both steel mate, first thing i checked when discovered the problem
Stub lengths are different, NS one being shorter and from the condition i'd say newer :?
New wishbone is the next step i guess, just hope im not going to find a whole load of knock-on problems :(
Did wander if someone had fitted an E36 one at some point, as AFAIK they are similar but not exactly the same
TouringMatt
Post Fri Jan 26, 2007 7:08 pm
In fact not long after a got the car i had to the replace the steering rack tie rod on that side as it had excessive play - possible it could have had a hefty knock at some point?
old_skool
Post Fri Jan 26, 2007 7:13 pm
Can you measure the pivot points with a steel rule or maybe snip some welding wire to the correct lengths and compare them - if you know what I mean :D
Look on the bright side, new after market control arms are cheap enough and if this is all it turns out to be then it's not much of a problem. :roll:
old_skool
Post Fri Jan 26, 2007 7:14 pm
From re reading this it sounds more like the control arm is bent. What has the tyre wear been like?
TouringMatt
Post Fri Jan 26, 2007 8:01 pm
Just had new tyres on but the old ones were worn more on the insides.........but they were on the car when i had it and i've put 24k on it since then
Just been under the car again (christ its cold!) cant really see much difference in measurements, but a used some soft wire to copy the inside profile of the OS arm, flipped it to the NS and the curvature is less on that side.....
They are definitely different makes thought, the balljoints are not the same. Booooooooooooooooooooooooooo :x
Taken from an old thread
The E36 wishbones are longer (wider track) and will bollox up your tracking.
Sound the same? I did have to force the lollipop forward to get it bolted up....
old_skool
Post Fri Jan 26, 2007 8:25 pm
Yep. Sounds right mate.
I have some control arms in the unit. 1 new and some used (can't remember which side the new one is). Let me look in the morning and I'll see what I've got - I can always parcelforce something up to you on Monday. Do you need the car for work Monday or ?
dazleeds
old skool raver
old skool raver
Post Fri Jan 26, 2007 8:33 pm
never had to force the lolli into position and have changed many
sounds like your spot in with e36 part :x how dare someone do that
www.oldskoolfantasy.co.uk
TouringMatt
Post Fri Jan 26, 2007 9:27 pm
Worst part is i've been driving around like that for nearly 2 years! :banghead:
Thanks for the offer dude. I can use my g/f's car for work if i need, have 5 days to get it re-tested before i have to stump up £45 again for a full test. Going to try GSF/ECP in the morning but if you could check that would be much appreciated :thumb:
dazleeds
old skool raver
old skool raver
Post Fri Jan 26, 2007 9:30 pm
hope i dnt find the same when i fit mine :roll:
they been sat here for weeks now but not getting done till car comes off road next month
Templ8e30
Post Fri Jan 26, 2007 9:36 pm
E36 arms are exactly the same dimensions as the E30 ones.
My wifes E36 318is needed new arms as the balljoints were fooked, compared them back to back with an E30 arm and they were identical bar the design of outer balljoint. It's now on E30 arms, had a 4 wheel alignment done and no adjustment was necessary.
Sounds like you've got a damaged arm.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
TouringMatt
Post Fri Jan 26, 2007 9:44 pm
LOL! That was your quote i used up there ^^^^ from this thread http://www.e30zone.co.uk/modules.php?na ... +wishbones
Fingers crossed changing it will fix the problem :(
Templ8e30
Post Sat Jan 27, 2007 2:33 pm
TouringMatt wrote:LOL! That was your quote i used up there ^^^^
Nice one, talk about contradicting yourself :o:
Cheers,
Iain T
TouringMatt
Post Sat Jan 27, 2007 2:50 pm
All sorted - ECP to the rescue :)
Took the old wishbone off and compared it against the new one but was convinced there was no difference :?
Bolted it all up and everything looks good, just need to get it re-mot'd and get the tracking checked
Thanks for all the help guys :thumb:
Matt
