auto to manual!
telski789
Post Thu Jan 25, 2007 10:02 am
hi,a 325i auto has come along nice and cheap and im wondering what has to be changed to make it a manual? i have only ever had manuals....is it difficult? cheers
Tel
stuartgallafant
Post Thu Jan 25, 2007 10:34 am
flywheel, starter motor, clutch, clutch fluid reservoir, master and slave cylinder, pedal box, ECU modifications, gear shifter, and of course, the gearbox!!
i dont think i've left anything out
can be done in a weekend
tee
Post Thu Jan 25, 2007 10:40 am
Dont have to modify the ecu stu. Mine ran fine when I converted the Alpina.. There is a plus where the DME connects to the to the vechicle loom and the EGS and you just disconnect it, as far as I remember. You might have to bridge the inhibiter switch but thats about it. Oh and dont forget the spigit bearing.
dom-1984-320i
Post Thu Jan 25, 2007 10:42 am
what sort of cost are you looking at for the conversion?
stuartgallafant
tee wrote:Dont have to modify the ecu stu... You might have to bridge the inhibiter switch but thats about it. Oh and dont forget the spigit bearing.
thats what i meant...
the spigot bearing will come with the clutch kit!
telski, tee is the man to talk to about this anyway, he did it in a weekend on his drive
tee
Post Thu Jan 25, 2007 11:03 am
Since when does the spigit bearing come with the clutch??
You thinking of the thrust/release bearing??
stuartgallafant
Post Thu Jan 25, 2007 11:05 am
yes, you're right!!! i havnt had enough coffee yet!! was up all night playing with one of those nintendo Wii things... they're the nuts!!!
isnt the manual prop slighlty longer too?
Theo
Post Thu Jan 25, 2007 11:32 am
The props are different, auto being shorter than the manual.
You'll also need the pipe which runs across the bulkhead connecting the two clutch cylinders.
stuartgallafant
Post Thu Jan 25, 2007 11:34 am
Theo325 wrote:You'll also need the pipe which runs across the bulkhead connecting the two clutch cylinders.
i would've thought that was obvious!!!
theo, dont you have all the parts needed for this conversion?!
Theo
Post Thu Jan 25, 2007 11:36 am
Just sold them I'm afraid.
I've got a lovely close ratio getrag 260 box which will let you hit 60 in 2nd though. You can have the clutch slave and prop shaft for free if you buy it telski.
stuartgallafant
Post Thu Jan 25, 2007 11:37 am
ask miniblob if telski doesnt want it
telski789
Post Thu Jan 25, 2007 11:58 am
doesnt sound too difficult then! i'll see what happens! cheers
Tel
tee
Post Thu Jan 25, 2007 12:56 pm
stuartgallafant wrote:yes, you're right!!! i havnt had enough coffee yet!! was up all night playing with one of those nintendo Wii things... they're the nuts!!!
I dont want to know about you staying up all night playing with wee things
tee
Post Thu Jan 25, 2007 12:57 pm
Theo325 wrote:The props are different, auto being shorter than the manual.
Yeh forgot about the prop
tee
Post Thu Jan 25, 2007 12:58 pm
Theo325 wrote:Just sold them I'm afraid.
How much for the gearbox mate.... cash waiting!
tee
Post Thu Jan 25, 2007 12:59 pm
Ooo look, just hit 100 posts. Got some catching up to do with you boys
Theo
Post Thu Jan 25, 2007 1:05 pm
Pm sent Tee.
stuartgallafant
Post Thu Jan 25, 2007 2:39 pm
tee wrote:Ooo look, just hit 100 posts. Got some catching up to do with you boys
Get whoring!!!
