Electrical gremlin in my touring!
Post Tue Jan 23, 2007 9:24 pm
It's a wierd one if you ask me, sometimes the radio cuts out when.........
i press the brake pedal,indicate, turn my lights on, accelerate heavy, no reason at all, turn the heater fan on! And if i have lights on and the heater like today then it doesn't like the volume wound up to high!
It just loses power for a slpit second is the sympton, then comes back on. As you can imagine when your driving in london traffic the radio on and off like a yo-yo can get a little annoying
The OBC display flashes brighter in a very similar fashion too.
I've replaced the engine earth off the sump as it was a bit iffy looking. This helped a little with the OBC flashing
yours,
the electrical muppet :?
SPADGE
Post Tue Jan 23, 2007 9:27 pm
Possibly a problem with the earths behind the glove box?
Dan318-is
Post Tue Jan 23, 2007 9:28 pm
Glove box, passengers side light and passengers rear seat earth all need to be checked si.
Also the loom connection box in the engine bay (cant rmember its proper name buts its located under the inlet manifold somwere i think; the pins rust and i remember they called all sorts of gremlins like this on Massive's sport.
Post Tue Jan 23, 2007 9:41 pm
First question is: Is this something new or has it always been like this? Radio could be connected to a wire that's not a 12V supply.
Check the earths as Spadge says, and also the two smaller leads on the battery + terminal.
There is a cap (female hex) bolt visible in the fusebox, which occasionally gets "got at" by the uninitiated. This bolt holds the main power feed to the fusebox, and a poor connection here can cause some strange effects.
Post Tue Jan 23, 2007 10:00 pm
I've had 2 head unit's in the car it's done the same with both. This has only appeared in the last few weeks..........all was good when i first used the car.
Thanks, i will try to find these earths adn check the other suggestions, handy as there is no glove box at the moment
Oh Brian remember i had problems with the ABS on my old sport? Well i did fix it in the end thanks! it was a sensor too like you said, it didn't help that the replacement sensor was duff also!
Post Wed Jan 24, 2007 2:21 pm
i've checked the above points and can't find anything really.
I did notice however that the radio had no earth, so i wired it in. And hoped for a cure but nope.
The earths behind the glovebox there are loads of them! lol
*Could it be connected to my dodgy instruments, speedo waves up and down a bit at speed, rev counter a little too and the temp guage just creeps up and up. You hit it and it sorts itself out! Or could that be something totally different and another bad earth!
Martinaston
Post Wed Jan 24, 2007 2:55 pm
If you've got a meter check the voltage across the battery while its running and see if it stays steady, it could be the alternator on the way out.
Is the radio wired via the 4 pin plug into the accesory sockets ? (big white one in the glove box)
There is NO nucleus.
Royalratch
Post Wed Jan 24, 2007 3:10 pm
You're not Martinaston, trials and MTB don are you?
Martinaston
Post Wed Jan 24, 2007 3:24 pm
If i lost a few pounds and actualy got on my bike i could be, but f**k that. I'll stick to driving.
Post Wed Jan 24, 2007 3:34 pm
yes some of the wiring ends up in those white sockets. Alterantor doesn't look very old and read a constant 13.45 volts. Does that seem about right. Would this figure go up and down when driving?
Martinaston
Post Wed Jan 24, 2007 3:42 pm
Sounds OK, It shouldn't go above about 14v when you rev it.
Have a go with all the lights on and everything else (rear window, radio,wipers) and see if it goes below 12v.
Post Wed Jan 24, 2007 3:53 pm
went down too 12.5/12.6 with everything going. And the radio was going on an off as i switched things on!
Could it be the xenon headlamps? the idle did drop a little when i switched them on.
I don't know cos i am hopeless :?
Martinaston
Post Wed Jan 24, 2007 4:23 pm
Na the drops normal, as long as it doesn't die. Its just the extra draw on the alternator (and a few BHP)
How are you at removing radios ?
Post Wed Jan 24, 2007 4:29 pm
Alright the one in there has only been in a week or so as the old one was a bit cheap and cheerful. The problem was here before i swapped head units. It's all easy access as there is no glove box and the central control panel is a bit fooked too.
Martinaston
Post Wed Jan 24, 2007 4:40 pm
Did you remove the bits of trim or has someone had a play before ?
I'd pull the whole lot out and trace every wire right back to its source, if the old one did it then its either a loose joint or as Brian said its on the wrong circuit. You also need to remove it to see if its linked to the problem with the dials.
(i've got a pic somewhere of the correct plug for the radio, still looking)
Martinaston
Post Wed Jan 24, 2007 4:43 pm
Wait hold the phone (brainwave), try disconnecting each speaker one at a time from the back of the head and see if it cures it.
I had a similar thing once where i put a screw through one of the sspeaker wires that grounded the unit.
Post Wed Jan 24, 2007 8:27 pm
Those alternator output figures seem too low to me.
Put a voltmeter between a clean part of the alternator body and the battery negative terminal. Should read zero volts. Any voltage here indicates a poor connection in the alternator earth return path.
If this is OK, it's time to try a new regulator pack on the alternator, or a fresh alternator.
Ant
Retired Team Member
Retired Team Member
Post Thu Jan 25, 2007 5:24 pm
Simon, you sorted the dodgy DME relay power feed yet ?
that will short now and again , the result could be the source of all the gremlins dude !
Post Thu Jan 25, 2007 7:03 pm
No Ant i havn't :o: i'll do something this weekend now i have licence to frag the auto of all things good
Oz bring the soldering iron round!
Brian i'll try this too
Thanks guys
