Which bolt is positive on an m20 alternator?
320Touring
Post Wed Jan 24, 2007 2:02 pm
is it the 13mm or the 8mm?
thanks
Post Wed Jan 24, 2007 2:08 pm
They both are, but the big one is the charge current out.
320Touring
Post Wed Jan 24, 2007 2:20 pm
Brianmoooore wrote:They both are, but the big one is the charge current out.
excellent!just need to check its charging ok.
thank you.
Post Wed Jan 24, 2007 2:23 pm
You check it's charging at the battery terminals. Look for a little over 14 volts.
320Touring
Post Wed Jan 24, 2007 2:47 pm
Brianmoooore wrote:You check it's charging at the battery terminals. Look for a little over 14 volts.
battery I have is gubbed though, so wanting to see whats happening on rest of circuit. if alternator is putting out ok, then all I need is a new battery as alternator is new.
