OBC problem
Greeny
Post Tue Jan 23, 2007 3:42 pm
Hi Guy's n' Gal's.
The obc on my cabby wasn't working when I bought the car but after getting on the zone i managed to fix it by disconecting it with the ignition on.
The problem I have now is that it keep's reverting back to the old problem just showing the 'PPPP' fault code and even when it is working the only thing which is accurate is the clock, the average speed only ever show's 0.2mph, tank range only ever show's 21miles and I can't get the outside temp to show oC when I change it MPG rather than litres per kilolometer or M/G (which i'm sure i managed to do on my old E34 530).
Is the OBC goosed or is it a wiring/sensor problem?
Any ideas?
Gone but not forgotten.
('92 325i Cabriolet)
Templ8e30
Post Wed Jan 24, 2007 1:18 am
Pretty certain 'PPPP' means the OBC unit is knackered :(
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Post Wed Jan 24, 2007 9:08 am
Greeny wrote: I can't get the outside temp to show oC when I change it MPG rather than litres per kilolometer or M/G
This is correct for the 12 button OBC - You get US, metric or imperial, not a mixture.
For the rest of the problems, PPPP is the fault code, but you say sometimes it works.
Is it sensitive to shock at all?
Loom is normally reliable, but it depends how it's been abused in the past.
Wriggle the connectors at the OBC and the cluster with everything powered up.
Greeny
Post Thu Jan 25, 2007 5:33 pm
The initial problem I had was that the bulb in the unit seemed to be blown but strangly one day when I moved my heater control's across slightly harder than normal the obc lit up, so it could well be a wiring problem. I'll give wriggling it a try. :eek:
CHEERS!
