coolent system problems
noney82
Post Tue Jan 23, 2007 8:48 pm
since yesterday my 325i has started a strange problem, all started when i was sat in traffic, the heater in car wen cold but came warm again when i drove, got car home looked under bonnet, the pipe the comes from the bottom of the rad(drivers side) up in front of the fan then curls round and connects into what i think is the stat housing is stone cold. but today the problem went all pipes were warm heater was fine, until 10 mins ago its doing it again, any ideas anyone please, wrong time of year for the heating to stop working lol
Post Tue Jan 23, 2007 10:07 pm
What's the temperature gauge doing when this is all happening?
Check the heater hoses are on the stub pipes on the bulkhead the correct way around.
Hose from the back of the head should go to the bottom stub.
noney82
Post Wed Jan 24, 2007 3:16 pm
temperature gauge is between quarter and half, heater matrix pipes are on correct way because they havn't been removed, water doesn't seem to be circulating around coolant system :?
Post Wed Jan 24, 2007 8:38 pm
If the temp gauge is between quarter and half, and stays put, then the cooling system is working properly!
Don't know from here why the heater goes cold.
Jesus325iTouring
Frog freak !
Frog freak !
Post Thu Jan 25, 2007 7:43 am
In my 18 months of a cooling system messing around I had most things happen to it,these symptems would suggest an airlock in the pipe work somewhere.
Try bleeding the system through and see what happens.
noney82
Post Thu Jan 25, 2007 6:03 pm
ok i'll try bleeding it see what happens im goes to flush it to thank you :D
Chris-W
Post Thu Jan 25, 2007 6:22 pm
Is this the car you've just replace the water pump on? As Jesus says (not often I use that phrase), you probably have a bit of an airlock.
noney82
Post Fri Jan 26, 2007 3:55 pm
yeah this the one mate. how can i get rid of an air lock? mate still selling car btw
dazleeds
old skool raver
old skool raver
Post Fri Jan 26, 2007 4:04 pm
noney
you got msn mate??
i can run you thru the procedure
Daz
www.oldskoolfantasy.co.uk
noney82
Post Fri Jan 26, 2007 4:26 pm
nonny82@hotmail.com mate will be on in about 20 tho mate
dazleeds
old skool raver
old skool raver
Post Fri Jan 26, 2007 4:27 pm
send me a msg when ur on fella
it will show me as offline but im there winkeye
ur added :D
noney82
Post Sun Jan 28, 2007 12:16 pm
spent 4 hours last night trying to bleed it up with no joy, got front end raised, rung car to quarter temp, open nipple air bubbles come out then steam atarts then the header tank blows over, leave to cold down, and there is no water left in system, any ideas?
