any megasquirt users use the idle valve
liam012
Post Mon Jan 22, 2007 11:19 pm
i think i would like to have an idle valve on my system as i often pop outside every morning and start the car half way through my morning cuppa and come back in and let it warm up - i enjoy the leisure of a turn of a key and no foot on the floor for 20 seconds to "reden her up".... after all this standalone must be able to do it well as its meant to be an upgrade!
did anyone else bother with one?
i am curious to what yoiu used
cheers
Ant
Retired Team Member
Retired Team Member
Post Tue Jan 23, 2007 10:14 am
I use ignition timing to prop the cold idle up Liam, you can set all the paramenters to suit your needs,
alternative is to use a golf warmup regulator, this will give you the fast idle as and when required, without the nightmare associated with a PWM idle valve.
liam012
Post Tue Jan 23, 2007 10:16 am
so you can turn the key and you have your cold start enrichments set to take care of everything to warm up?
what do you do- add more fuel and set to spark in later?
Ant
Retired Team Member
Retired Team Member
Post Tue Jan 23, 2007 10:20 am
the map I put into your MS has the WUE already on there Liam.
To prop the cold start idle up, increase the Ignition timing to reach the desired level, Cant recall if I enabled that on yours, its a while back and it was a Beta Test item when I implemented it on mine, workds well though.
Email me back you map file to the Flatbars addy and I'll give it a once over again M8, things have moved on a little since last summer, may as well get you up to date :thumb:
