Front wishbone bush - how easy?
TouringMatt
Post Mon Jan 22, 2007 4:38 pm
Big un that sits inside the lollipop, can i leave the wishbone attached to the car and just unbolt and remove, or does the whole lot need to come off to do the job
Powerflex concentric ones look well priced and much easier to fit - are they :mad:
Cheers!
Matt
Royalratch
Post Mon Jan 22, 2007 4:51 pm
Has to come off. New one needs to be pressed in with a hydraulic press.
Ziggy
Post Mon Jan 22, 2007 4:55 pm
If you say so...
I've done them a couple of times on the car with no probs.
Yes, the powerflex ones are easier to fit, they come labelled the wrong way for left & right though! :mad:
The most annoying bit is getting the old ones off, but that'll be easier if they're FUBAR. :thumb:
charlE30
Post Mon Jan 22, 2007 4:58 pm
You don't need a hydraulic press to fit the Powerflex bushes but it'll help to get the old ones off, failing that use a saw and blow torch (old ones out) :twisted:
Yes mate you need to remove the lollipop to fit em and it'll most probably be easier to remove the wishbone aswell as the old bush will most probably be well stuck to both parts.
Fitting is a doodle, follow the instructions that come with the bushes...
BMW F31 335d xdrive
Royalratch
Post Mon Jan 22, 2007 5:02 pm
Ziggy wrote:If you say so...
Yes we know you can hammer them off and cut them off with a saw and stuff.
I assumed he wanted to do the job 'properly'.
TouringMatt
Had a look when it was up on the ramps at the MOT place (yep, it failed :( ) and it looked fairly easy, NS one is indeed FUBAR, OS looked ok-ish, better to replace in pairs tho me thinks :)
As long i can use brute force, powertools and ignorance i should be ok :D
Cheers for the input guys
Chris-W
Post Mon Jan 22, 2007 5:53 pm
It's no problem removing the bush & lollipop with the wishbone on the car, using a gear puller. Easiest if you cut the lollipop free first, ie. through the rubber.
oze30
Post Mon Jan 22, 2007 8:07 pm
I had to get a shop to press the bush into the lollipop.. or you can buy e36 ones with them already in. Puting them in is easy enough. I did it under the car. I used a large-ish socket to wack the bush on the last bit. But it all works now!
Ziggy
Post Mon Jan 22, 2007 8:57 pm
Chris-W wrote:It's no problem removing the bush & lollipop with the wishbone on the car, using a gear puller. Easiest if you cut the lollipop free first, ie. through the rubber.
Hegzactly. I'm not sure how that's not doing it 'properly'? I guess if you want to keep your old bushes for posterity...! :mad:
Chris-W
Post Mon Jan 22, 2007 9:03 pm
Quite agree. You can remove old consumable with a shotgun and, as long as you don't damage anything, be doing it 'properly'.
TouringMatt
Post Mon Jan 22, 2007 9:49 pm
Well i ordered the E46 rear mounts ( another failure, i only replaced them with ECP E30 ones 14k miles ago! ) from BMW, just need to decide which route to go down with the bushes, Powerflex or OEM
Got a few gear pullers so removal will hopefully be ok
oze30 - how much did you pay for the E36 ones? Are they better and are they a direct fit?
Cheers :)
Post Tue Jan 23, 2007 9:20 am
There is not the slightest need to remove the control arm to replace the bush.
Take the weight of the wheel (don't remove it, for safety reasons), and unscrew the two bolts holding the lollipop.
It won't spring away, and can easily be fitted back on its little locating bushes.
Remove the lollipop with as much rubber as possible, using a sharp craft knife and twisting the lollipop.
Assemble a hacksaw with the blade through the hole in the lollipop and cut through the outer metal sleeve of the bush, and push it out. Clean up the lollipop.
Cut or grind through the inner metal sleeve on the bush, and pull the remains off. Clean up the control arm pin.
Take your new standard OE E30 or E36 M3 control arm bush (don't use aftermarket stuff, rubber or plastic), and press it into the lollipop, taking care to line the locating marks up. A decent vice is good enough to do this.
Coat the bush centre and arm pin with 50:50 washing up liquid and water, and push it on by hand. You have to work quickly, get the lollipop bolted back on, and the car back on the ground before the lubricant dries out.
Bounce the suspension a couple of times to settle the bush, pour hot water over the bush to remove as much lubricant mixture as possible, and leave the car for a few hours.
**BANNED**
Post Tue Jan 23, 2007 2:56 pm
If using powerflex bushes,check and check again that they are fitted the right why round.The resess(?) on the lollypop part faces the front....
E30Mark
Post Tue Jan 23, 2007 3:06 pm
daimlerman wrote:If using powerflex bushes,check and check again that they are fitted the right why round.The resess(?) on the lollypop part faces the front....
Yep, the ones marked RH go on the left, the other marked LH goes on the right :mad:
PM for details
Ziggy
Post Tue Jan 23, 2007 3:09 pm
Did you know that they also come labelled the wrong way for left & right? :P
Royalratch
Post Tue Jan 23, 2007 3:30 pm
Royalratch wrote:Has to come off. New one needs to be pressed in with a hydraulic press.
I meant the lollipop has to come off to change the bush. You guys really do it with the lolipop still on?
The car should be tracked / aligned straight away too.
Ziggy
Post Tue Jan 23, 2007 3:58 pm
Royalratch wrote: I meant the lollipop has to come off to change the bush. You guys really do it with the lolipop still on?
Of course not! Aside from being sheer madness, would it even be possible? :mad:
But the original question was about whether the wishbone needs to come off...
Royalratch
Post Tue Jan 23, 2007 4:07 pm
I know - I saw control this and arm that and got confoosed.
Anyway, Brianmooore has answered now so everyone STOP!
TouringMatt
Post Tue Jan 23, 2007 4:15 pm
Thanks as ever for the replys guys, and thanks for the walk through Brian, very much appreciated :thumb:
Matt
Nelly
Gumbo
Gumbo
Post Tue Jan 23, 2007 4:39 pm
Matt, with your Tourer that low, i would use P/F bushes - it will end up a harse ride fella as an every dayer?
But, a the end of the day, it's your car and your choice as i keep telling my self lol.
Neil.
"I F**KING LOVE YOU GUMBO"
TouringMatt
Post Tue Jan 23, 2007 4:46 pm
Thats a bit of a trick sig pic - the front OS wheel was up on a slope and it was packed to the roof with a weeks worth of camping gear :) Here is it as it normally sits, although the front is a touch higher as i finally got round to fitting the KW -40mm springs that match the rears
