Advice on 325ise
jacko323i
Post Mon Jan 22, 2007 12:20 pm
Been offered a tidy e30 325ise but wot i wanna know is does the ise come with the limited slip diff? As its wot im after?
Geeman
Post Mon Jan 22, 2007 12:22 pm
Not as standard fella. It might have one on... depends on what was specced when new, or if a previous owner fitted one.
HTH
Post Mon Jan 22, 2007 12:29 pm
LSD diffs have an "s" stamped on them somewhere, if you can see this underneath all of the barnacles that are probably on there, it is unlikely to have one though
jacko323i
hmmmm ok giles cheers mate, if not is it fairly straight forward to put a slip diff on this if i get 1 for her?
cheers beemer lad
Post Mon Jan 22, 2007 12:33 pm
it's a straight forward swap, just gotta make sure you get the correct ratio from another 325 as the 318iS had a LSD fitted as an option but the ratio is not correct so I understand. I think you need either 3.91 or 3.73 but that's where I run out of talent on this subject :)
Contact someone like JonB, usual price for LSD is £200+
Geeman
Post Mon Jan 22, 2007 12:34 pm
Yeah... 'reasonably' straight forward... as long as you can get it in the air... it's a just a bolt-in procedure. :wink:
jacko323i
Post Mon Jan 22, 2007 12:44 pm
nice 1 thanx lads, brill, yea can soon get her on a ramp, i can get access to a few garages to use a ramp wen not busy or use the local college if john or wayne will let me in :wink:
Geeman
Post Mon Jan 22, 2007 12:45 pm
cool. Will have to come and have a look at it. :wink:
jacko323i
Post Mon Jan 22, 2007 12:48 pm
yea its not far from ur house mate at all. Off to ave a look at it this afternoon so fingers crossed pay a deposite on thurs n get it the followin week :wink:
snoops
Major Helmet
Post Mon Jan 22, 2007 5:55 pm
just jack the baack up n turn one wheel if the other turns the same way its got an LSD but if it goes the opposite direction the its an open diff
