Engine mounts
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Jan 22, 2007 9:29 am
Hi guys,
need to do both engine mounts this weekend.
anybody got basic procedure or pitfalls to watch out for
much appreciated,
thanks
charlE30
Post Mon Jan 22, 2007 10:57 am
Are you doing the rubber or the full mounts? Rubbers are dead easy mate, did mine a while back. Put the car on axle stands, trolley jack (with a lump of wood) under the engine to support it. Undo the nuts, raise engine enough to clear the bolts using the trolley jack, remove rubber mounts and replace then as they say "refitting is reversal of removal"
Good luck
Charlie
BMW F31 335d xdrive
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Jan 22, 2007 11:02 am
Just the rubber I think. The engine has "fallen off" sits just on the very edge of the rubbers now.
charlE30
Post Mon Jan 22, 2007 11:07 am
What engine is it? my above post was on an M20 2.5 but I'm sure the same procedure applies to other engines..
Mine also "fell off" rubber mounts split in two 8O
Don't forget to undo the earth strap from chassis to engine mount (metal part)
BMW F31 335d xdrive
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Jan 22, 2007 11:13 am
Mine is just an m40 but I think you're right.
I've been told elsewhere that it's just a case of supporting the engine, undoing bolts and replacing.
charlE30
Post Mon Jan 22, 2007 11:28 am
I had to lift the engine slightly to clear the bolts from the mounting holes in the sub frame. Haven't seen M40 mounts though..
BMW F31 335d xdrive
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Jan 22, 2007 12:04 pm
Cool. Thank man. Guess I'll find out at the weekend :)
