Central Locking getting on my ti*s again!
Dan318-is
Post Tue Jan 16, 2007 10:00 pm
My central locking had been playing up recently andi narrowed it down to (as usual) the central locking module. Now i bought a spare of simon1 (whos touring, ironically, had the same fault later that evening :? ) and fitted it to mine. Job done, or so i thought. Left the car outside for a few days and got in the car to go out and yet again the central locking had stopped working. Removed the ECU, and found it was logged with water and that the connections were wet; exactly like the first one i removed.
This is now the third time i have replaced my central locking moduele; the second one has water proofed in abag and the seals taped and mounted with the pins facing upwards and it STILL got water in it; everything else on my system is perfect working order as i have had to change all four locks and do minor re-wriring on the alarm system before so i know its the module; but how the hell do i stop water getting into it? and were is it coming from?
and its not the jacking points simon either so dont suggest that!
Ziggy
Post Tue Jan 16, 2007 10:04 pm
It's not the water getting in, it's that it can't get out again: Blocked cill drains. Won't be doing any good rust-wise either to have all that water sat there...
Dan318-is
Post Tue Jan 16, 2007 10:05 pm
how do i unblock them?
Dan318-is
Post Wed Jan 17, 2007 11:54 am
any ideas?
Dan318-is
Post Sun Jan 21, 2007 8:04 pm
Anyone no how to unblock these!?
Post Sun Jan 21, 2007 9:16 pm
Look up under the car. Several slots where the cills join the floorpan.
How you clean them depends on what's blocking them, but stiff wire is an obvious choice.
