Upgrading from 6 button OBC to 13 button OBC?!
bmwe30mtech
Post Sat Jan 20, 2007 7:03 pm
Hi,
Just wondering if:
a. Its worth it (in your opinions!)
b. What extra is needed? Im guessing its not just a case of plugging in the same wires :?
Also am i right in thinking the 13 button OBC does not do temperature in degrees C?
I only ask as a mate has one he doesnt want!
nickso
Post Sat Jan 20, 2007 7:30 pm
it does do degrees C but you cant have the correct MPG and degrees C at the same time.....ive just learned how to convert to fahrenheit in my head.
you will need the whole loom as well as the indicator stalk and probably some other stuff ive missed.
you may also need a different temp sensor as some folk have said they had trouble with their 6button one. mine seems to work ok though.
to be honest other than the mpg, temperature and time functions i dont use anything else at all.
'88 e30 328i M52 track bint.
mattG
Post Sat Jan 20, 2007 7:32 pm
it does do temp in c, but you need the stalk to go with it,
i'll be interested in th 6 button is it just a digi clock?
bmwe30mtech
Post Sat Jan 20, 2007 7:36 pm
Matt, no it does time, date, temp, and memo i think.
I have just seen a tech article, will read that .
nickso
Post Sat Jan 20, 2007 7:55 pm
mattG wrote:it does do temp in c, but you need the stalk to go with it,
you wont get degrees C with the right MPG......only a problem if you are interested in your mPG i suppose.
Simon
Post Sat Jan 20, 2007 9:25 pm
Don't bother, the 6 button is much better!
Pain not having the temp read in C. The other options are american and german.
Also, the 6 button can be changed to 24hr clock, a lot more adjustable!
bmwe30mtech
Post Sat Jan 20, 2007 9:28 pm
Thanks guys.
Simon im thinking I will stick with the 6 button also.
I think it was only sports and SE's that were fitted with the 13 button anyway, so its more than many had anyway.
Simon
Post Sat Jan 20, 2007 9:30 pm
SE had 13 button fitted as standard, 13 button was optional on all others.
M3 was fitted with 6 button as standard, 13 button an extra.
bmwe30mtech
Post Sat Jan 20, 2007 11:22 pm
Thanks for that info Simon. Im trying to make my car sport spec using all genuine parts (i usually dont like coppies, but finding a genuine sport with no rust in excellent condition at a fair price seems impossible now!), so am glad the sport could come with the 6 button.
Thanks.
