what head gasket for a 325/....
iggy-rs
Sat Jan 20, 2007 6:57 pm
i need to replace mine, where is the best place to get one and how much??
cheers in advance
Templ8e30
Sun Jan 21, 2007 2:26 pm
Try www.gsfcarparts.com go to the online shop.
B11438 CYLINDER HEAD GASKET SET E30 325i 85>91 M20 BQ £42.50
You'll need new head bolts too. It's also a good idea to fit a new cambelt and tensioner at the same time.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
**BANNED**
Sun Jan 21, 2007 2:32 pm
Just a thought,have the head pressure tested whilst it is off,no point putting it back cracked....
E30Adam
Sun Jan 21, 2007 4:01 pm
I'd use nothing but a dealer gasket, not that expensive and you don't hear of so many failures like you do the gsf ones.
For a few quid extra, it's worth paying not to have to repeat such a long job and possible head cracking if the gasket fails.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
fuzzy
He who sleeps with "Gingers"
Sun Jan 21, 2007 4:05 pm
can you get cometic steel 3 layer gaskets for the m20? theyre re-usable up to 10 times im told although maybe thats only a bonus in my case :D
iggy-rs
Sun Jan 21, 2007 8:25 pm
cheers people, i will get a proper one i think, might do it on saturday.....should be fun
E30Adam
Sun Jan 21, 2007 8:29 pm
It's not that bad, just time consuming.
One really important thing to remember is just before you put the new gasket on, make sure that both surfaces on the head and the block are absolutely spotless and free of any oil. Use sh!t loads of carb cleaner to get those surfaces good enough to eat off. Also make sure there's absolutely nothing in the bolt holes on the block. Some people think if there's a little bit of oil, it won't matter and will squeeze out when you put the bolt in... wrong! It won't come out and when compressed while you're winding the bolt in can crack the block.
Sun Jan 21, 2007 10:57 pm
What do we think of elring gaskets people? Ive always considered them one of the best and would use them over a genuine gasket :?
