BBS Alloys
Car-Nut
Post Sat Jan 20, 2007 4:44 pm
Whats the easiest way to clean them, its such a pig of a job.....
Clive
Things are changing in the stable....
'88 Zinnobar Red E30 325i (Sold and missing it :O( )
http://www.carandclassic.co.uk/car/C50851
'02 Inidividual E39 M5(SOLD)
Pal318is
Post Sat Jan 20, 2007 5:14 pm
No easy way, I would have thought, just elbow grease :) maybe get them acid cleaned??
Pal
Pal
Image[img]http://Image
dom-1984-320i
Post Sat Jan 20, 2007 5:22 pm
Get your self some 'Meguiar's Hot Rims All Wheel Cleaner you can get it a Halfords for about £6.99 i think. Spray it on, leave for a few ins and jet wash it off, its amazing stuff and save alot of messing around with toothbrushes and such!
drewjak
Post Sat Jan 20, 2007 5:28 pm
once a week with wheel acid and a large pipe cleaning brush to get in between the spokes then rinse it off, if you keep on to of them its a doddle try not to bake hard all the time helps as well
snoops
Major Helmet
Post Sat Jan 20, 2007 5:52 pm
yep acid cleaning is good no point spendin tym on em with toothbrushes etc
gazza
Post Sat Jan 20, 2007 6:07 pm
acid is good but if there are any areas on your wheels where the alloy is exposed and the paint is missing/chipped then it will get under the paint and cause more corrosion and start to lift the paint in time .....dont use it to often unless they are really minging
ShineOn
Post Sat Jan 20, 2007 6:14 pm
Use Wonder wheels or whatever if you have too, but dilute it 5 or even 10:1 with water first.
A better product is Muc Off, the pink coloured cleaner. Very effective but won't eat the wheels, and won't cause problems if you have broken laquer from stone chips or kerbing.
Then spend a bit of time (once clean) applying a dedicated wheel sealant, Chemical Guys Wheel Guard for example. Will take a while to apply, but will make it an utter piece of piss to clean after that with just a bit of soapy water or even the hose (if you can use it). And much better than normal wax because its designed to stand up to the higher temps the wheels get to.
drewjak
Post Sat Jan 20, 2007 6:23 pm
gazza wrote:acid is good but if there are any areas on your wheels where the alloy is exposed and the paint is missing/chipped then it will get under the paint and cause more corrosion and start to lift the paint in time .....dont use it to often unless they are really minging
wot kinda acid u usin? battery acid! , i do mine every weekend and have done for exactly 56 weeks since i re painted them last christmas, i scuffed 2 of them in the first week down to the alloy and mine aint flaking off, and they get powerwashed/steam cleaned twice a week, may be its down to product type, or have you had your wheels furbed incorrectly?
not looking for an argument gazza, just wheel acid is excellent stuff and is some times the best way with bbs type alloys that have been neglected.
e30_singh
Post Sat Jan 20, 2007 6:42 pm
i used boiling hot water with some washing up detergent whatever you want and spray it on, leave it on for a bit and use a toothbrush if extremely dirty and if you can jet wash the holy bejesus out of them!!
mrLEE30
Post Sun Jan 21, 2007 3:34 pm
found a bottle cleaning brush it the best, it gets into the knooks and crannies quite well and does n ot remove the skin from your knuckles!!
