Update - the M20 flywheel
DOESN'T fit straight on an M52. I thought it did when I had it all together finger tight, after torquing it up the back face of the flywheel touches some of the block's webs and the 'tunnel' for the flywheel inspection/locking cover. It's a 2 minute job to grind the webs back the fraction enough to clear though.
jaistanley wrote:What diameter id the M20 clutch? I have an S50B32 engine and the M3 3.0 (5spd) gearbox and would like to loose the heavy flywheel too..
Will the clutch be up to the job?
The M50/M52/S50 flywheels are 240mm diameter, the M20 is 228mm. I worried that the clutch wouldn't be up to the job so did some investigating. A 4wd Sierra Cosworth and a Subaru Imprezza both use flywheels the same size as the M20 one. They make 300 lb/ft easily with bolt ons and are harder on clutches due to the 4wd. Neither seem to have excessive clutch problems. I reckon it'll be fine, especially with an uprated plate and cover.
councilboy wrote:The M52 might have more than 200 bhp but it won't have anything like the torque of a blown 300 bhp M10
Won't it...?
