M42 profile gasket re-fit - please help!
cheesebox
I've taken the day off work to put the cylinder head back on my 318iS, after a strip down to replace the profile gasket which had failed.
My question is, what type of sealant should I use on the gasket, if any?
Swift advice would be much appreciated, if poss. I've finished enamelling the head and it's ready to go back on now.
I'd like to get the job done properly - I'm not planning on replacing it again, ever!
Cheers guys
Cheers guys
cheesebox
Reading around it looks like "no sealant" is the answer, just make sure all surfaces are clean.
Ant
- Retired Team Member
No sealer on the front setion, for the rubber strip that runs under the head I use a small dab of sealer where the metal faces meet each other, but only in that area, ie small blob on each section and pop the rubber strip into the grove
clean, clean and clean again are the bywords dude,
Email FTW
cheesebox
Thanks for the advice Ant. I'v cleaned obsessively for the past 3/4 hour, ready to go with the head. A
For the mating metal areas, does it matter what sort of sealant, I have some blue hylomar and some liguid gasket - which would be better?
Templ8e30
You mean on the head gasket ?
Again no sealant of any kind on a head gasket.
Use a little silicone sealant on the ends of the rubber timing cover seals but nothing else.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Dan318-is
Any pics of the offending profile gasket?
cheesebox
Just uploading some before and after pics - will post here shortly...Dan318-is wrote:Any pics of the offending profile gasket?
Head's on now, thanks for your help guys
Ant
Now why didn't I put it so plainlyUse a little silicone sealant on the ends of the rubber timing cover seals but nothing else.
Email FTW
cheesebox
Here are the before and after pics of the offending culprit:
Yuk! Note much chance of reusing this gasket, arf arf:
Distinct improvement!
and here's the cylinder head ready to go back on. Quite pleased with the engine enamel:
Next job is to replace all the timing sprockets, guides and chain. Planning to finish the rocker cover in crinkle black. Will update with pics...
Dan318-is
Chrikey! thats a nasty one! lots of horrible brown poo everywhere. Is this the first time its been changed or was it mixing etc?
Looks like a good job then!
cheesebox
It's the first time it's been replaced. It failed at 80K miles. The timing chain tensionaer was the old type. Both jobs should have been done under warranty, but bmw tell me it hasn't been done - they can check on history from the VIN.
There was no mixing, just increasingly bas loss of coolant from under the tensioner - seems other people have had similar failures, without mixing of collant/oil, looking at the zone forums.
Dan318-is
why didnt you go to BMw and get it done or is it to old?
cheesebox
Not an option unfortunately, according to Williams BMW/Autotecnik anyway. Seems the warrty only lasts a certain time. Shame...
Dan318-is
Interesting. Mine was originally done by a BMw garage in maidstone and they made a right fucking mess of it; so bad in fact that i think itswhy it failed again.
Glad its all sorted mate
