Brian Mooooore
TW166Y
Post Wed Jan 17, 2007 6:21 pm
Hi mate, few electric issues i hope you could help me with if possible.
My e30's been stood for a while in the damp winter conditions we are experiencing at the moment due to me only been able to do the conversion in stages.. week by week and sometimes month by month. This time the car had been stood for around 8 weeks, when i came to it at the weekend most of the electrics seem to have died on me, could this be due to damp getting in the fuse box or something ????
anyway problem 1
Heaters will no longer blow
problem 2
petrol gauge and temp gauge no longer work. the clocks i am aware of are buggered, although the two listed faults worked before it was stood!
another problem with the clocks are that there is no ignition lights either BUT the car starts fine, indicating a battery fault but its a new battery ???
Thanks Brian and to anybody else who may help.
Pete :wink:
Saying goodbye to 4-pot wrongness
TW166Y
Post Thu Jan 18, 2007 4:15 pm
Nobody know then :?
Post Thu Jan 18, 2007 7:07 pm
Patience, lad, patience! One of the last tourings I bought had been unmoved for over two years, and was full of water inside, to the top of the wheel well and rear pockets. New battery, a bit of fresh fuel and some air in the tyres, and I started it straight up, freed up the clutch and drove it a hundred miles home. Parked up for a mere 8 weeks is nothing.
Problem 1: Usually down to the unloader relays connection to the starter motor. Pull out relay K5 and short together pins 30 and 87 of its socket.
Problem 2: Fuel gauge is a simple circuit, and doesn't normally fail completely. Check out fuse 10.
Ignition light is another simple circuit. No fuses involved at all here, just a feed from the ignition switch to the bulb and then to the small terminal (blue wire) on the alternator. Goes through the C101. This screwed up completely?
Varied selection of faults with no one single cause, IF everything else works!
TW166Y
Post Fri Jan 19, 2007 3:01 am
hmmmm a lot of that i couldnt understand, your too technical for me, lol. Ill pop my bins on tomorrow, sit down with a mug of hot coffee and study, what your explaining. Hopefully something will click in my bain and ill be able to cure them all. :P
cheers brian mate, pete
