Hi everyone,
I'm going to look at a 1992 325i Touring (manual) at the weekend, quite a lot of miles (169k), but with full service history and well spec'd by the looks of it. I've wanted an E30 for ages, but whilst familiar with the E36 and its little problems, what can you tell me to watch for on the E30 that might bite me in the arse?
Thanks,
Paul
Advice on what to look out for
bigmattpowell
Rust mainly. wheel arches, fuel tank, fuel lines,scuttle under windscreen,rear hatch, around windows. If you can drive it, try and look out for play in the bushings- wandering rear end round bends or over bumps, and front end under braking etc. Other than that, general car old stuff, have a good poke around, look for mayo in the oilways etc. Tourings are made well but anything that can wear out will wear out eventually, just make sure the basic body is good and the engine sounds fine, doesn't smoke or steam and pulls all the way up the revs. Oh, and rust again.
ShineOn
Thanks for you advice Matt. Do they suffer the same things as E36 suspension then? i.e. front bottom ball joints and rear trailing arm bushes?
'From the pitcures' it looks pretty mint, but up close and personal is a different thing. I don't mind a bit of dull paintwork (I'm a detailer), but rust is my biggest concern.
bigmattpowell
check out the 325i buying guide at the top of the "cars for sale" forum- some good general advice there. I'd say front control arm bushes, arb drop links, rear subframe bushes(not easy to change), suspension top mounts. Yours is 92 then should be fine if it's been looked after. As Brianmoooore says, as long as the shell isn't rusty then anything else mechanical can be dealt with on the zone- any question you need answering or part you need can be had within a few minutes of posting on the zone, and help can usually be had if you dangle the offer of tea and a packet of biscuits!
ShineOn
Chocolate hobnobs are the currency of the conossieur!
bigmattpowell
ah, with this hobnob you're really spoiling me
orangecurry
does the E36 really have rear trailing arms? Apart from the compact of course.ShineOn wrote:Thanks for you advice Matt. Do they suffer the same things as E36 suspension then? i.e. front bottom ball joints and rear trailing arm bushes?
Did Matt mention to look out for rust? You don't want much on the front suspension towers either.
ShineOn
I'm sure thats what they are called, at least the stealer knew exactly what I meant when I asked for the part when mine were toast.
I get the impression rust is a priority.......I have read the E30 M3's are often ravaged by bulkhead rust, makes sense that the rest are the same. The guy who owns this car is an enthusiast, and says he spent a long time looking for this car (and looked at a lot of shitters when doing so), so fingers crossed this isn't rotten.
