start to finish 335ic project (formerly www.335itc.co.uk)
BristolBulldog
Post Tue Jan 16, 2007 10:29 pm
Ok, my previus website www.335itc.co.uk i took down, costing me over £100 to run per year, due to the 1700 odd photo's on it.
I am in the process of setting it up to run from home. for now i will be adding pic's linked from hosting site's.
Thanks for looking.
I will try and link the pics in some kind of order, but for now its jsut to show roughly what the car looks like, and how the work has gone etc.
I will split it into three sections. bodywork 1st section, mechanics 2nd section, interior 3rd section.
BristolBulldog
Post Tue Jan 16, 2007 11:07 pm
Before
BristolBulldog
Post Tue Jan 16, 2007 11:19 pm
Bodywork
BristolBulldog
Post Tue Jan 16, 2007 11:26 pm
Mechanics
gareth
Post Tue Jan 16, 2007 11:49 pm
looking good! :D
what coilover conversion is that?
BristolBulldog
Post Tue Jan 16, 2007 11:50 pm
hehe. home made.
custom 2.5 inch springs on the front. the rear springs, and all shocks are spax psx.
The front strut is a standard modified 325i strut.
the picture of the circle with all the holes drilled out of it, is the support platform. its a 1/4 inch thick plater washer used to support the spring cup. this is substantially thicker than the standard bmw strut (providing my welding was up to scratch!)
Cloggy Saint
Post Tue Jan 16, 2007 11:57 pm
Is the inlet manifold painted or polished? If painted, what did you use? :cool:
gareth
Post Tue Jan 16, 2007 11:58 pm
all home made inc the threaded parts etc? did you know you can buy essentially the whole setup for a front coilover kit for about £70 in whatever rate / length springs you want.... these have a weld-on threaded sleeve instead of a seperate aluminium one.
fair play to you though, it looks very nicely done :D
BristolBulldog
Post Tue Jan 16, 2007 11:59 pm
i ground off the top casting seam to make it look more tubilar, and then sprayed it in cellulose "chrome" paint. Still nothing like chrome, but looked good when i did it! i did my multiple throttle bodies in it as well.
gareth
Post Wed Jan 17, 2007 12:00 am
datourer wrote:Is the inlet manifold painted or polished? If painted, what did you use? :cool:
i suspect the spraycan and silver overspray are a clue! silver engine paint?
BristolBulldog
Post Wed Jan 17, 2007 12:05 am
gareth wrote:all home made inc the threaded parts etc? did you know you can buy essentially the whole setup for a front coilover kit for about £70 in whatever rate / length springs you want.... these have a weld-on threaded sleeve instead of a seperate aluminium one.
basically i purchased coilovers for the front, powder coated, for £150. with springs and threaded tube.
i later found out they didnt have the abs sensors.
Instead of paying a company to do it, i took my strut, found suitable platforms, and made them fit. i then welded the top and bottom after removing the old strut platforms.
DRIFTBOY
Good work dude!
I like the M3 kit and and the rear axle with Z3M diff cover! :D
BristolBulldog
Post Wed Jan 17, 2007 12:06 am
think it was just wheel paint. given the high solids metal type content it should be very good at dealing with decent amounts of heat.
BristolBulldog
Post Wed Jan 17, 2007 12:08 am
DRIFTBOY wrote:Good work dude!
i like to drift, and really do drive the car at most opportnites. so thought the cover and its extra capacity was a must.
The whole car is poly mounted, so i had to do the diff mount. there is a significant difference in flex. not sure how it affects the drive yet.
The diff is an m5 diff with e30 flanges.
DRIFTBOY
Post Wed Jan 17, 2007 12:13 am
Mine is all poly bushed too apart from the Z3M diff bush - but I would like one of those diff covers if I ever find one.
Glad to hear the car gets driven properly despite the time and effort gone into it! It would be a waste otherwise! winkeye
BristolBulldog
Post Wed Jan 17, 2007 12:22 am
i imported mine. most of my parts were imported. i found i either couldnt get them over here, or they cost too much.
Pal318is
Post Wed Jan 17, 2007 3:19 am
This looks excellant bud...some superb pic's too.
Pal
Pal
Image[img]http://Image
BristolBulldog
Post Wed Jan 17, 2007 9:09 am
hehe.
on the other forums people couldnt understand why i didnt just buy an m3.
it was obvious to me.
1. ruin a good classic (the m3)
2. i bought the m3 kit, almost totally intact for £350!
3. i have modified almost everything, so there would be little point buying an m3 only to butcher it, and change which side drive it was, full suspension overhaul etc.
4. my car's wider at the back b over and inch than a standard m3.
5. the m3 suspension is different, and for some reason i cannot remember my coilover conversion wouldnt have worked.
BristolBulldog
Post Wed Jan 17, 2007 9:14 am
here's a pick i thought i'd never see:-
(i was in the boot, drilling and fitting the brackets for the anti roll bars, and she had to sit on the front to hold the front of the car down!). she rebuilt the rear handbrake assembly with a litte guidance. I'm trying to convinve her to help em some more. we had the dash out and a new one fitted in less than 20 minutes. Apparently its very similar to changing a quilt cover!?!!!
i think this is my album url link
http://s116.photobucket.com/albums/o6/B ... ?start=all
i will add more. there are so many and it takes ages to.
getting excited now about getting back on with here. a few of the people on these forums helped me figure out the hoses etc, and its spured me on to get the bloody thing finished. going to make another serious attempt at a summer release!
Andy335Touring
Post Wed Jan 17, 2007 6:18 pm
toby
Post Wed Jan 17, 2007 10:19 pm
I remember your website - it was very good. You certainly work hard dude.
BristolBulldog
Post Wed Jan 17, 2007 10:23 pm
Thanks Toby. Unfotunetly for the last 6 months or so i have gotten caught up renovating a flat, building custom pc's and whatever else comes my way.
I'm now determined to finish her! and work hard i will!
I will not be spraying her to a professional standard as i originally intended to. I would have to learn it like everything else. I bought the equipment, but i really just want it on the road. so it will have a rough sprayjob for 07, and a repsray and engine refresh in 08.
jonb
Post Wed Jan 17, 2007 10:52 pm
Hello craig.
Its jon from bristol here. Fucking hell you still got that cab? You still got the engine i sold you?
BristolBulldog
Post Wed Jan 17, 2007 10:58 pm
hey mate! yep. making a renewed attempt to finish!
the engine i bought from you has had the head re-done totally, 288 piper cam etc. the block has been re-done as well, and i'll be fitting m5 throttle bodies as well. Every single seal has been replaced etc etc. Hoping that will go in this coming xmas. i bought a spare engine, and thats going in for now.
Just tryingto get a complete new hose set at the mo, and the chrome strips. Sold the six i had as well. just waiting for it to be collected.
Hows u? did you ever get that 318/335 running ok?
jonb
Post Wed Jan 17, 2007 11:10 pm
Yes mate.
That was done a long time ago. Got it running but never finished, long long story etc etc.
How much did you get for the 6 in the end?
we need to go out for a few jars again!
BristolBulldog
Post Wed Jan 17, 2007 11:13 pm
never finished? u still have it or sold it? tell me more lol!
six went for 1650, which was good.
Last time we went out for jars you started on people, and ran off when they came to "chat" about it!!!! waht was that, 3 years ago? lol.
jonb
Post Wed Jan 17, 2007 11:25 pm
Christ you got a good memory craig. That was about 4 and a half years ago! Dont time fly....
The car was broken in the end, some paddy offered me really good money for the whole conversion. Ive owned plenty of other scrap since. :)
