mikeyboy
Post
Thu Jan 11, 2007 2:06 pm
I have a query i have some OZ ultraleggera in matt graphite only available in et 37, i need spacers.
I have heard three different things;
10mm
15mm
20mm told by rimstock
i need to know by people who love the e30 as much as i do cause im not messing up my ride for nothing.
Any help?
hairydave
Post
Thu Jan 11, 2007 2:28 pm
What width are they?
Gouki
Post
Thu Jan 11, 2007 3:01 pm
15mm spacer would be perfect for them whats ur width?
mikeyboy
Post
Fri Jan 12, 2007 1:30 pm
the wheels are 7" wide;
7 x 16
mikeyboy
Post
Fri Jan 12, 2007 1:31 pm
also does anyone know where i can get the spacers from? and then the bolts? locking wheel nuts?
Gouki
Post
Fri Jan 12, 2007 2:57 pm
15mm will be fine, that will bring it nicely to the arches, 20mm more so, you should be able to get hubcentric type spacers from ebay, there's a company who also do them with the longer bolts
http://www.performancefx.net/wshome.htm if you click that they do one for the E30 in those sizes you wanted.
orangecurry
Post
Fri Jan 12, 2007 3:57 pm
10mm would be ok as well - brings the offset to 27, and as BMW 7" rims have an offset of 24 IIRC that's only 3mm 'out' as opposed to 2mm 'out' with 15mm spacers...
205/50/16 tyres would be perfect.
Gouki
Post
Sun Jan 14, 2007 11:56 am
considering that offset between 15-25mm is fine any of those sizes are suitable depends how far to the arch you want your wheel!
I've bought spacers from that company with no problems. The hubcentric kits come with the longer bolts and they come in diff offset sizes. Delivery was fairly quick too.
mikeyboy
Post
Mon Jan 15, 2007 1:56 pm
any suggestions though? what is the alpina reps on? and the 5 spokes in your picture?
Gouki
Post
Mon Jan 15, 2007 3:26 pm
the 5's never had spacers but were the wrong offset IIRC 35mm! The Alpina reps I think around 15-20mm?
d6dph
Post
Mon Jan 15, 2007 3:33 pm
Do not listen to Rimstock, 20mm is far too much from personal experience. The 17's on mine caught the front and rear outer arches, I'm now running 10mm on the front and 15mm on the rear with no issues.
HTH
Dave
mikeyboy
Post
Mon Jan 15, 2007 6:24 pm
cheers dave, i know the guy there i spoke with was a bit of a muppet to be honest
d6dph
Post
Mon Jan 15, 2007 7:43 pm
Well mine are Rimstock wheels and I followed their advice 100% as the shop I work for deals directly. But obviously they have some very wrong info on the fitment!
I hope you are using hubcentric spacers?
mikeyboy
Post
Wed Jan 17, 2007 8:40 am
will be getting hubcentric definitely.
m-dtech
- Unapproved Trader caution
Post
Wed Jan 17, 2007 10:51 am
can get them from here
http://www.priracing.com/product.php?xProd=186
also you will need longer bolts.
id recomend you convert to nuts as spacers are a pain in the ass.
universal studs & nuts from the above link.
i had alloys with an ET of 40, used a 20mm spacers and converted to nuts.
TW166Y
Post
Wed Jan 17, 2007 10:57 am
i also have some for sale
Saying goodbye to 4-pot wrongness
