whats this? oil leak
snoops
- Major Helmet
i noticed oil all over my drive and decided to get the engine washed so i could see where the leak was coming from, this is where its leakin from as it looks like the pipe has caracked but what is this and how much does it cost to fix?
http://img45.imageshack.us/my.php?image=image002qh2.jpg
snoops
- Major Helmet
snoops
- Major Helmet
snoops
- Major Helmet
wildeian
Are we looking at the pipe behind the elec. connection with the spring at the base??
It's the oil return from the head to the sump
snoops
- Major Helmet
i think so its the pipe that looks like a 'U', how much does this cost to fix/replace?
wildeian
The oil return is a straight pipe from head to sump, looks like an 'I'
snoops
- Major Helmet
lol its gone bent now, how much is it?
wildeian
wouldn't of thought much, just a pipe with an 'O' ring at the top, and spring at the bottom.
Anyone who's breaking an engine should have one for sale
snoops
- Major Helmet
thanks for the info
kam-325i
the pipe has an o ring at the top and bottom....the top sits in a cavity in the inlet manifold, the spring at the bottom holds the bottom oring in place.
snoops
- Major Helmet
yep thats the one
If the oil return pipe on your engine is bent, something very strange has happened to your engine in the past! It certainly can't get bent while sitting in place on the engine.
It has an O ring seal, top and bottom, which don't normally give trouble unless the pipe has been disturbed, or refitted without fitting new O rings.
kam-325i
The pipe has been bent ?????
How did that happen ????
GDBN
I would have thought when the head was replaced.
G
G
I deserve 6 of the best ...
snoops
- Major Helmet
i dunno but as wildeian said it looks like an 'I' but mine is like a 'U'?
jamesh1977
- BEWARE Zone Thief
ive got one from a 320i im breaking if you want it ?
snoops
- Major Helmet
you have pm jamesh1977
