Rough idle when cold
Stumpy1
Post Sun Jan 14, 2007 9:02 pm
My m20 25i Sport runs quite rough at idle. Its getting worse and seems to want to stall when pulling away too.
It also seems to be running rich as it smells fuely.
All these things happen when its cold, when hot its sweet as.....
Ash
Stumpy1
Post Mon Jan 15, 2007 4:28 pm
bump
win
Post Mon Jan 15, 2007 4:35 pm
I've been getting the same thing on my 325 in the last week i'm not sure but i'm going to change my fuel filter as i've already done engine temperature sensor.
Win
Post Mon Jan 15, 2007 10:33 pm
Blue temp sender and/or plug and socket on the metalwork under the middle of the inlet manifold.
Stumpy1
Post Mon Jan 15, 2007 10:57 pm
I put a blue temp sender on today but no joy. Whats the plug under the inlet manifold for Brian?
Post Mon Jan 15, 2007 11:17 pm
Stumpy1 wrote:. Whats the plug under the inlet manifold for Brian?
Carrys the signals to the injectors and from the blue and brown temp sensors.
Stumpy1
Post Mon Jan 15, 2007 11:24 pm
I'll trace it all the wiring back tomorrow and make sure. Will probably stick it on the gas analiser as well and make sure my mixture doesnt just need adjusting.
