Clutch problem
jacko
Location: Too near Lakeside for comfort, even when in Spain
Post Sun Jan 14, 2007 8:48 am
I made the journey to work this morning (yes sunday, and i'm still there), a distance of about 10 miles, only thing is my clutch pedal has started to sink about halfway just by resting my foot on it. Its not doing it all the time and it doesn't seem to do it with the engine off, whats going on and is it going to get me home?
marty1979
Post Sun Jan 14, 2007 8:54 am
Hi there, have you had a looked at the clutch fluid reservoir? If you're loosing any fluid the level will have dropped.
jacko
Post Sun Jan 14, 2007 9:01 am
yes just had a look and it seems to be up to the level.
Chris-W
Post Sun Jan 14, 2007 9:05 am
Master and/or slave cylinders on the way out, I'd suggest.
jacko
Post Sun Jan 14, 2007 9:16 am
Oh great, what sort of job is it, are the bits easy to get?
Chris-W
Post Sun Jan 14, 2007 9:44 am
Master cylinder sits above the clutch pedal, remove from inside the car (take drivers' seat out for improve access), slave sits on gearbox, so you need the car raised. Bleeding the system once new parts are in place can often be time consuming.
Bits easy to get from ECP/GSF/Dealer.
jacko
Post Sun Jan 14, 2007 9:48 am
Cheers Chris, much appreciated.
