stitch-626
Post
Sat Jan 13, 2007 5:39 pm
just fitted an alarm with remote start and it wont work. it turns the ignition on, then cd player etc goes off for a momentm (like when starting with the key) but the engine doesn't turn over.
its the third day tring to figure it out and i'm just scratchin the skin off my head and arse.
any shed any light on this problem
cheers
wanted passenger side rear door for touring.pref dark blue
wanted, toy Bmw's any series, not for me for my 3year old daughter.
I have a rondevous with death, i drive an E30 in scotland
Post
Sat Jan 13, 2007 6:53 pm
Simple - you haven't wired it right!
You'll have to say how you've wired it if you want us to suggest how it should be wired.
stitch-626
Post
Sat Jan 13, 2007 7:08 pm
12v constant =red
acc on = green
ignition on = purple
starter =green/grey
thats wired up the way the instructions and this link
http://directwholesale.net/diagrams/dia ... D=53&link=
i know that it says black/yellow for the starter but there isn't a black/yellow wire so i put 2&2 together and got green/grey.
E30Mark
Post
Sat Jan 13, 2007 7:18 pm
Where did you find the green/grey wire?
There should be a blk/yellow wire from the ignition switch... on pin 50
I'm sure Brian will put me right!
old_skool
Post
Sat Jan 13, 2007 7:21 pm
I'm sure the green/
black is for the unloader relays, not the starter. That is why the radio is going off when it is trying to start? Hopefully i'm right otherwise Brian will Boll*ck me as he told me all about this recently
Post
Sat Jan 13, 2007 7:22 pm
Think you've put 2&2 together and made 5!
Never seen an E30 starter wire any colour other than black/yellow. Where did you find this green/grey wire.
stitch-626
Post
Sat Jan 13, 2007 7:27 pm
the green/grey wire sits next to the pyrple wire on the big red connector.
the only other wires are black (same thickness as the ones ive already mentioned) and four thinner wires (cant remember the colours off the top of my head i'll check tomorrow if you need me too but i'm sure brian will know)
no sign of a black/yellow wire
old_skool
Post
Sat Jan 13, 2007 7:28 pm
What car are you fitting this on?
E30Mark
Post
Sat Jan 13, 2007 7:32 pm
The starter should have 4 wires going to it
Black / Green - Goes to the unloader relays
Black - From battery +ve
Red - To alternator
Black / Yellow from ignition switch
Post
Sat Jan 13, 2007 7:33 pm
Starter wire is black from the switch to its connector.
Don't go much on those instructions - They have you butchering the looms all over the place.
Most of the required connections, including the starter signal, are accessible around the glovebox area.
stitch-626
Post
Sat Jan 13, 2007 7:42 pm
cool i'l unsolder the wires and start again with the advise given i'll let you know how it goes.
thanx again ppl
stitch-626
Post
Sun Jan 14, 2007 4:46 pm
yay it works!!!!!!!!!!!
E30Mark
Post
Sun Jan 14, 2007 5:13 pm
Now just don't start it in gear!
stitch-626
Post
Sun Jan 14, 2007 10:10 pm
i'll try nd remember that. espesially after i tried it this affy (letting the missus try it out). its ok cos you can stop it as soon as you rember that its in gear hehehehehehe
