Hello,i'm preparing my car for track days, i'm going to lower it, my question is, is changing the springs a enough or should i change the shock absorbers aswell as the springs. How much of a difference will it make if i just change the springs. I have a 318i if this makes any differemce to the answer,thanks.
Also, looking on ebay i found this. Does anyone have an opinion on this particular set up.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
Lowering my e30
Ant
- Retired Team Member
change the dampers too dude, always the best way, also retrofit a rear Anti Roll Bar (ARB) as not all 4 cyl cars had them, and those that did had puny ones
Dont forget to fit vented discs up front too, raid a 325 for the whole front legs and get better damper choice too.
HTH
HTH
Email FTW
oguz327
- Captain Armco
Welcome to the zone fella
It depends on your budget really but i would say if you can deffo go for shocks and springs together, should make a big difference.
There some good kits on the zone shop, H & R or a Bilstein combo's being your best tryed and tested bet.
toby
eurocarparts.com does a cheap bilstein lowering kit with shocks and springs. Bilstein are good shocks. You could also do a search of the forum and select the motorsport section for trackday setup recomendations and compromises if the car is still going to be used on the road.
