Cooling system woes...
Cyruz
Post Fri Jan 12, 2007 3:42 am
It's an early m20 2.5
Don't I love old cars... I've recently serviced my car but not done more than 40miles since, all running smooth and fine. The temperature gauge will only come up to 1/4 and then only slightly over after coming to a stop in traffic after some fast driving. I removed the thermostat and dumped it in boiling water to check it's not jammed. It opened fine and closed in cold water. I take it it's fine to drive hard as coolant is still flowing around the block, getting hot air in the cabin and pipes are still hot (barring one)...
The second ball ache is the pipe from the bottom of rad is cold about 3/4's of the way toward the bottom of the thermostat housing. I think I've got an air block somewhere, tried bleeding it a couple of times and still seems to have a block. Also when empty the rad it only spills slowly unless you blow through the expansion tank and then it free flows as normal.
Thermostat + seal, blue pin and brown pin are all new.
Cyruz
Post Fri Jan 12, 2007 3:50 am
Another quick question, whats the thread on the standard sump plug. I'm looking in to a magnetic one.
GDBN
Post Fri Jan 12, 2007 11:04 am
Why do you want your temp gauge to move higher ?
If it sits about 1/4 it's fine ...
If it's not overheating what's the problem ?
G
I deserve 6 of the best ...
stranter
Post Fri Jan 12, 2007 11:58 am
If oil doesn't get up to the correct temperature, it doesn't work properly, that's why it's important to get to the right temp!
Hmm, not sure about an airlock, they usually in my experience, result in overheating. Maybe a gauge problem? IIRC the needle can be loosened or tightened...or am I going mad?
Stewart
Martinaston
Post Fri Jan 12, 2007 4:16 pm
If the guage now sits in a lower position its probably due to the new temp sensor having a higher resistance, as long as you can see the needle move slightly as the thermostat opens and closes its fine.
When you drain the coolant the header tank tank is below the top pipe so it won't just run out, take the top hose off and it will drain in no time. If you want all of it out then you need to drain the block as well which means getting the plug out behind the exhaust manifold.
There is NO nucleus.
