goosiegander
- Zonegoose
Post
Thu Jan 11, 2007 11:29 am
As it says chaps, if you could outline a brief step by step of getting the wings off that would help me out no end ...i have a plan
hahaha!
Best regards!
Chris-W
Post
Thu Jan 11, 2007 11:36 am
Remove:
Front bumper (2x T55 or 10mm bolts underneath)
Plastic arch liner (various 8mm screws)
Headlight surround grille (2x phillips screws and 3x clips)
Bumper support bracket (1 of 2x 10mm screws
Row of 8mm screws along top edge
2x screws below 'smiley' light unit (lower one is allen key - 4mm?)
2x 10mm screws inside wing, at door shut end
I think that's everything.
goosiegander
- Zonegoose
Post
Thu Jan 11, 2007 11:42 am
Much appreciated, i assume its a long drawn out process with much swearing, anything i need to be really careful about, in tearms of avoiding damage to the wing/fixings?
Chris-W
Post
Thu Jan 11, 2007 11:45 am
Not really a bad job - just remember to unplug the front indicators when you remove the bumper; cut the seam sealant at the scuttle and unplug the side repeater.
I also forgot an 8mm screw at the bottom of the arch, at the sill!
goosiegander
- Zonegoose
Post
Thu Jan 11, 2007 12:01 pm
Thats much appreciated!
Best regards
jcjdavis1
Post
Thu Jan 11, 2007 8:04 pm
Hi I think you might get some comments about the USS Enterprise,a wee bit big.
Post
Fri Jan 12, 2007 12:43 am
Plastic bits under the wheelarch are the worst part of the job - assyuming that the bumper bolts are nicely copper greased, and, yes, if you could make the "Enterprise" a little smaller, please.
kevin316i
Post
Fri Jan 12, 2007 1:37 pm
The plastic nuts at the top of the underside of the plastic wheelarch liner are likely to be seized. Suggest some WD40 on these before trying to remove them, otherwise the studs may break off.
goosiegander
- Zonegoose
Post
Fri Jan 12, 2007 3:26 pm
Much appreciated chaps, very helpful, can't resize that avatar so replaced with old school Enterprise
ian332isport
Post
Sat Jan 13, 2007 2:40 pm
goosiegander wrote:Much appreciated chaps, very helpful, can't resize that avatar so replaced with old school Enterprise
Still a bit big though
goosiegander
- Zonegoose
Post
Sat Jan 13, 2007 2:53 pm
Well thats the best i can do for now, need to develop those editing skills i guess...
Post
Sat Jan 13, 2007 6:19 pm
Someone's done it, 'cause it's spot on now!
