M30 getting ready . . .
kabeer
some snaps added. On the way home, as "pal318" request, taken on my phonecamara outside the garage as there is no space. weather is cloudy, the place is filthy, going to rain soon . . . .but another E30 will be salvaged from de-commissin and a new "M30 foutus" (black 320) will be ready by X-Mas here . . . .
http://img91.imageshack.us/img91/8913/outstreetye0.jpg
http://img92.imageshack.us/img92/6904/outst2dx7.jpg
http://img176.imageshack.us/img176/8673/outst3frih1.jpg[/img]
Proud to say, First E30withM30 in Kuwait.
hammoj28
Looks dam cool. Are your rear lights home diy? I need something very similar.
24v tech2
kabeer
sorry for the late response . . rear lights are filmed outside to match the body color.
kabeer
Some pics added as the work delayed due to bad weather and i was on sick leave. So far, M20 block removed and the firewall mods made. Also need to replace top waterhose, flywheel bearing, crank oil seal on M30 and transmission mounts . I'll be using a slightly modifyed E32 engine mounts. An engine clamp found from Crysler newyorker is looks to replace the engine brackets. I'll measure it tomorrow. Now i'm having some difficuelty in finding a proper transmission cross member in place of 320. needs help from zoners . . . .
Mec Ashraf clearing out all the remaining patrs of the blown M20
GETRAG box resting at top left corner . . .
Dentor Basheer is hammering the filre-wall and made a hole inside about 2 inches
Heater core pipes sew off to make more space . . .
...and some new replacement parts for M30
gcorky
- Boost Junkie
fugazi33
That looks like a cool project, is there many E30's in Kuwait?
DRIFTBOY
If the 320i gearbox cross member is the same as the 325i one (???) then use that. I bolted my 325i one to the 535i E34 gearbox and the long slots on the E30 floor allowed me to fit it where it needed to go with no modification.kabeer wrote: Now i'm having some difficuelty in finding a proper transmission cross member in place of 320. needs help from zoners . . . .
I used the 325i gear linkage rods on the 535i gearbox to get the gear lever through the floor in the right place too.
Keep us updated with how you get on! Good luck!
kabeer
Well, as far as i know, not more than 25 E30s and many are not daily driver. most of them are taken to neighboring countries like Jordan and Turkey. moreover, this place is always having an impression that OLD IS OUTDATED & INFERIOR feeling, it's hard to find clean E30s.
many E30 owners are expats and never seen a LOCAL(kuwaiti) behind an E30.
For the parts, i'll have to relay on local junkyards, presently hunting for a E28 radiator, were i can find de-badged rare 2002ti's, E12's, E21's with little damage. I have a plan to restore a 2002 after the M30 job gets over.
Driftboy says :
But i can see there's a difference of 4inches in the gearbox mounting bush area. Mec says we'll have to alter it. I'm using a E34 535i box and linkage rods.
Driftboy says :
Pal318is
Some good pic's there kabeer....you expect this to be done before xmas...that a long project bud...keep the pic's coming as you keep modding
Pal
Pal
Pal
[img]http://
[img]http://
gooner1
- Out humping Reindeer
Looking good Kabeer, but that geezers name is a joke aint it?
No offence if it isnt.
jonb
councilness kuwaitie style. love it.
Andyboy
- Alpina Colada
Councilness knows no bounds. Wbatever country, whatever creed or religion - you will discover councilness.
Pal318is
gooner1 wrote:. . .
I actually thought the name was a fake one...
Pal
Pal
[img]http://
[img]http://
kabeer
Nice comments guys. . . No.. they are all real life characters . . and watch their work and your comments on E30zone thru my lap. . . .poor labour people. . . .pulling their life. . . ,but that geezers name is a joke aint it?
Bytheway, any other radiator option to replace E28 radiator or can modify stock E32 rad ? comments please . . .
Andyboy
- Alpina Colada
What about my mate Biggus Dickus? And his wife Incontinentia Buttocks?kabeer wrote:but that geezers name is a joke aint it?
kabeer
WOWVOO...cute names and easy to call . . .
While searching for E28rad, found the engine oil filter with oil cooler rad from a E34. i'll b replacing the stock oil filter. it will be a good insurance for coming summer days were the mercury cross above 50 degree and most of the LOCALS migrate to your island (London is their second home).
kabeer
Sorry for the long delay . .some office works . .then was waiting for the NEW 325 crossmember. it took one month from BMW. E30 325 gearbox CROSSMEMBER AND RUBBER MOUNTING : is a must if the conversion is doing on a 316, 318 or 320 auto.
Used original E32 radiator, 2 lower water hose used for both lower & upper. Bypass the heater core lines.Both the left & right side of the chassis is cut to accommodate large E32 rad. By doing this, future overheating issues resolved & a MUST for the GCC.
reduced 18mm Front impact shocks length to cut chassis. poli bushing all around the chassis.
reduced 18mm Front impact shocks length to cut chassis, tho gives a bit of ratty look. this's the only way to get in the wide E32 rad.
Finaly mighty M30 in . . . .
last week there was a "dust rain" !! and the result was this !
and custom engine mount needs some finishing touch-ups..
Now moving on to the wiring. main plug is connected without ECU and all interior, dash, a/c blower fan ect. are functional. rest is inside engine bay. .
FUTURE PLANS :
poli bushing all around the chassis. lowering springs, m30 finned diff. cover
E34 exhoust header pipes NEED some mods & Bypass cat converter. Rear box: magna flow, flow master 5 series or stock rear box from E32/34
Battery relocate to rear boot.
BODY :
New paint job. Applied V-cool heat protection films
some parts i'll robe from my current 318i. such as 300mm steering, JVC head unit and my favourite 16" BBS, which will be swapped to the M30.
HUNTING FOR :
a nice 3.73 LSD diff.
Guys, comments (all type) please . .
[/img]
FUTURE PLANS :
BODY :
HUNTING FOR :
[/img]
