1.2W bulbs
mark_i
Post Wed Jan 10, 2007 3:48 am
where can we get a list of the correct wattage bulbs for an e30?
none of the wiring websites seem to give this info.
can anyone confirm if the 12V, 1.2W bulb is used for the following areas
1/ instrument cluster warning lights eg oil pressure, ABS, brake wear sensors, battery charge etc.
2/ rear ash tray
3/ headlight/foglight switch cluster
4/ headlamp level adjuster illumination
5/ OBC button illumination
not sure if a 0.5W bulb was used for some of the illumination functions to avoid melting the holder.
aus325
Post Wed Jan 10, 2007 4:47 am
pelicanparts.com list dashboard instrument globes as 12v 3w
mark_i
Post Wed Jan 10, 2007 5:57 am
OK, the 3W instrument dash one is covered already.Thanks
I'm interested in the items I listed as 1-5.
Mark
aus325
Post Wed Jan 10, 2007 6:28 am
OK, the only other one I know is,
1/ cluster warning lamps ........ 1.2watt part number 62 13 1 383 311
mark_i
Post Wed Jan 10, 2007 9:31 am
talking about illumination,
what about the tiny globes used in the origianl radio/cassette, anyone been able to replaced the dud 'uns?
