Got a whine at the rear,
Dubaholic
Post Tue Jan 09, 2007 11:59 pm
took my E30 out for a spin last nite and i took her up to quite a high speed (3 figured number) after this when i slowed down i cud hear a whining sound from the rear, gotta be my diff aint it??
it sounds the worst when i let off the throttle or hold it at low revs.
E30Mark
Post Wed Jan 10, 2007 12:08 am
That or the wife...
PM for details
Dubaholic
Post Wed Jan 10, 2007 12:10 am
how can i find out where its coming from?? cheers
mrLEE30
Post Wed Jan 10, 2007 5:20 am
diff or axle bearings, if its only a whine on decelleration i would not bother as not an easy repair, could also be worth changing the diff oil too (dont forget to remove the filler plug BEFORE you remove the drain plug)
if you want more whining then you should not be doing three figure speeds on public roads, unless your speedo in km/h winkeye
mrlee
Dubaholic
Post Wed Jan 10, 2007 9:50 am
cheers, ill have a look,
its in mph mate only bought her the other day wanted to see what she can do lol
