using e36 injectors
andrewpany2002
hi, could i use e36 316i injectors on my e30 316i ? would there be any benefits or isnt it a good idea ?
Turbo-Brown
- Boost Junkie
If they're the same impedance and flow rate at the same pressure then you can use them. If not, then don't bother or they'll throw your fueling out/bugger up your injector drivers or just not work.
Chris-W
andrewpany2002
o ok, so what else could i do clean or improve my ones ?
Turbo-Brown
- Boost Junkie
You can send them off for cleaning.
There's nothing to be improved by fitting different ones though
E30Adam
What's wrong with the ones in your car?
There's no point fitting different ones if you're are performing as they should.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
