tps
win
Post Tue Jan 09, 2007 4:55 pm
I had a look at my TPS the other day but it is not a 3 pin switch as i've seen in most pictures its round with about 6- 7 pins, is this normal? the car is a 325i switchable auto.
Post Tue Jan 09, 2007 9:32 pm
It's perfectly normal on a switchable auto, since the gearbox ECU needs info from the TPS as well as the engine.
win
Post Wed Jan 10, 2007 8:12 am
Cheers Brian, Is the test to see if its operating correctly still the same as the 3 pin switch?
Win
Post Wed Jan 10, 2007 8:45 am
Tests for engine idle and WOT switches will still be the same, but I don't have the pin details.
