Fule economy & tyres
Jesus325iTouring
Frog freak !
Frog freak !
Post Mon Jan 08, 2007 11:01 pm
I just came back from my holiday in Cornwall,and kept an eye on my miles and fuel costs.
The trip down door to door was 224 miles,this was completed with five adult size passengers,a dog and a 8ft trailer weighing about 300kg.
obviously the same again for the return trip.
Whilst there I covered 250 miles which was all done on small B roads with lots of hills and gear changing,most of the time with a full payload of passangers.
Thats a total of 698 miles.
All driving was of a gentle nature,and I never once exceeded 3000 rpm in any gear,nor did I go over 60.
I spent a total of £116 on petrol,when I got home I still had between half and quarter of a tank left,bearing in mind when I originally filled up I was well under the R line!
Having done a bit of calculating I can't be arsed to type up,with what I had left,and with using regular unleaded costing 88.9p per ltr I returned in the region of 23MPG.
Pretty damn good I reckon.
Secondly,tyres.
Before I left I fitted two new front tyres....
NANKANGS!
They have had a lot of bad press on here,but,I v'e now covered 750 miles on them.
All mileage has been done at standard driving,meaning,keeping to the limits and driving to the conditions.
I have got to say they have been perfectly fine,they are comfortable to drive on,don't aquaplane,don't cause under/over steer and generally quite quiet.
As i say,this is all on regular bog standard driving,If I was to wind up the car and drive like a phsycopath on crystal meth,then they may not be up to much,but for everyday day use,just the job and only cost about £39 each. (205/55/15).
Jon_Bmw
Dangerous when thinking
Post Tue Jan 09, 2007 12:49 am
See now that sounds not very good to me Rog, I think its because i'm a stingy bast**d. The audi weighs 1750kgs, so probably about the same as your e30 + passengers + trailer. As I told you, its down to an appauling 18mpg round town, but on a cruise if i was to drive as you described i would get 28mpg+.
I would have thought cruising up and down you would have averaged almost 30mpg, but perhaps not if the engine is working hard the whole time? The 250 miles in low gears up hills probably would be about 21mpg...so all things considered its about right :mad:
Most unhelpful post ever
BUT
Congrats on the wee nipper thats on the way too, i can't think of a sensible name yet.
Jesus325iTouring
Frog freak !
Frog freak !
Post Fri Jan 12, 2007 12:03 am
Jon_Bmw wrote:See now that sounds not very good to me Rog, I think its because i'm a stingy bast**d.
Me too :D
Thats about right,the main trips were pretty good,I put £40 in before I left Penzance and it went up to a little under full,by the time I arrived home I still had between 1/4 & 1/2,I reckon,even withmy tight wad attitude thats fairly good.
Jon_Bmw wrote: Most unhelpful post ever
Made me laugh,sounds like typing before thinking :lol:
Jon_Bmw wrote: Congrats on the wee nipper thats on the way too, i can't think of a sensible name yet.
Cheers Jon :thumb:
Post Fri Jan 12, 2007 12:08 am
I bet you drive round on 50 psi for less rolling resistance :D
Jesus325iTouring
Frog freak !
Frog freak !
Post Fri Jan 12, 2007 12:17 am
DanThe wrote:I bet you drive round on 50 psi for less rolling resistance :D
LOL!
Don't be ridiculous Dan,what a silly suggestion..........................if you want good economy it needs to be 65psi minimum :D
Jon_Bmw
Post Fri Jan 12, 2007 2:35 am
I hope you kept your seats flat, that helps economy :eek:
(you need to have seen a certain thread about a young nipper in a corsa /\ )
Actually i'm getting images of rog almost lying flat driving along using a mirror complex to see with the seat reclined as far as it goes just to get that imaginary extra MPG. PMSL
