How much of a pain is it removing the sump on an M42 as it looks like my sump gasket might have gone!
Had a look at the engine i've got out of the car and it looks like there two bolts that actually sit inside the bell housing, is this the case?
Dave
Removing SUmp on M42
Kedge
stuartgallafant
Dan318-is
The lower sump simply pulls of; 20x 10mm hexbolts and thats that; easy to change the gasket; the upper sump however im not so sure i think its a case of the lower timing case etc being removed.
Lower sump should be a doddle though
stuartgallafant
Kedge
Upper sump it is indeed guys, maybe a job for when i renew the steering rack on roll bar then!
stuartgallafant
Bob_S
about 3hrs work... I unbolted the engine and lifted it on a jack to get the sump out when I smashed my lower sump
Bollocks to this 24v scrap!
