Bad water leak M42 Lump, Continued, Pic's
Royalratch
Will do - cheers for that.
Can't believe BMW did you like that - makes my blood boil. Reason I don't go there anymore. They just give older cars to trainees to 'practice' on and rarely have anyone in there that has been around E30's much. You can't plug a computer in and swap the part real quick, they don't want t know...
If it does get worse and the head does have to come off, I will for sure get the whole thing done. I have that 2.5-3K timing chain rattle even though I fitted a new tensioner too...
Kedge
Is mayo a tell tail sign of the profile gasket failing then, because mine had no mayo at all anywhere!
Dan318-is
Mayo occurs when water and oil mix. In an engine without a profile gasket (e.g. all other engines), then generally mayo under the cap means that the head gasket is going as its the only place water and oil can mix. On the m42 however, it could be head gasket or profile gasket as the profile gasket seperates and oil and a water channel. Having said that, it could be a whole number of other things on the m42 lump e.g. timing case, water pump gaskets etc etc. If you have no mayo kedge and its leaking then are you sure its not a corroded coolant hose going into the head on the other side of the throttle body?
Kedge
Pretty sure its the profile gasket, if you look on the first page theres a picture of where the water was leaking from.
Dan318-is
Maybe it corroded in a weird enough place to only leak water. Tbh fella if you have a dry workshop or shelter and light the job isn't that bad to just time consuming and lots of bolting on and off. Probably worth pulling the head and having a look. Does it overheat?
Dan318-is
here are pics of my failed profile gasket; as you can see i caught it early and its minor compared to Duffs17's; still enough to cause mayo to occur though;
Kedge
The engine is out now ready to be played about with now!
Temperature was fine until it started running low on water, the water would come straight out without starting the car if i filled it enough!
Kedge
I'll try and get mine striped down next weekend and see what the damage is!
Dan318-is
This is a weird one kedge! Can you get the head of today id be interested to see the state of the inside?! Hope its not major.
Were you running antifreeze during the cold weather, not just water?
Kedge
Might be able to get it off tomorrow morning, got to go out soon today. Everything is off the head so shouldn't take long to get the head off!
Yea i was using antifreeze, whether its anything to with the car being stood for most the summer because i was in plaster and couldn't drive.
Dan318-is
Ouch
what happened? I really am out of ideas on this now; maybe tim might have an idea? I suppose if it was sitting there it wouldnt do it any good but if it had antifreeze in it and wasnt being stopped and started all the time i dont see why it would leak like this.
Just re looked at that pic kedge and i would say it has to be profile gasket mate!
cliffy, you chrome c*nt, how are things going with duffs?
Kedge
Smashed a bone in my left hand mountain biking and bugger the ligaments in my right so could just about steer but gear changing was out of the question!
I can't think of anything else it might be to be honest, but it does sound like weird symptoms compared to what everyone else has had!
Dan318-is
sheesh nasty! Well yes i had oil and water mixing but not that badly and my gasket wasnt that foobared, just very perished. If you look at cliffys gasket, which is completely obliterated, he was leaking water out the same place as you but was also not mixing oil and water; so i reckon it must be that.
Kedge
cliffybabe
- Powered by Nelly
Kedge I thoughts dufs was bad but bloody hell, thats a real mess.
Duffs had minor pitting like a blemish in comparison to ur's
Kedge
Mine sure aint healthy, i'm guessing theres probably going to be issues with the head!?
Dan318-is
That block might not even be reusable! ouch!
stuartgallafant
Kedge
Oh dear its that bad is it, i'll get it cleaned up and post some more pictures. Hopefully the engine in there now will stay fairly drama free while i plan what to put in there next!
cliffybabe
- Powered by Nelly
duffs is now back on the road and all better, he's a happy boy
stuartgallafant
Kedge
Finally got some bits of my block and head cleaned up a bit, sorry for the poor quality but you can just about make out the pitting on both surfaces. The top pic is the block and the bottom the head. I'm guessing the head is only worth its weight as scrap now but would the block be reusable if someone had a decent timing case for it? I'm not going to be using it as I've got a bit of a cylinder deficiency at the moment.
stuartgallafant
Kedge
The engine in the car at the moment seem fairly sweet so going to leave that in there for the time being, no chain rasp at all, my local specialist said it seems ok as well just seems to be over fuelling a little for some reason, any ideas?
Think I'm going to go down the engine conversion route now as I'm really missing the low down torque and smoothness my touring had.
stuartgallafant
Dan318-is
could be blue temp sensor or any other number or sensors kedge; do some voltage/resistance checks on them or get a diag; blue temp sensor is worth changing anyhow.
any clearer pics dude?
Kedge
I'll get the voltmeter out and check everything then, maybe a silly question but how do you go about adjusting the AFM?
Dan, i'll sneak my dads camera out and get some clearer picks in the week but it certainly doesn't look agood at all!
stuartgallafant
Dan318-is
i woudlnt go near that screw unless you have hydrocarbon and monoxide reading emmision machines; its not as simple as jsut turningit and hoping; get a diag and do some readings mate
Kedge
changing the oil and plugs next weekend and i'll checkout the sensors, if its still not right i'll take it down a local garage and let the pros have a look!
Dan318-is
Kedge, take some readings and rite them down; iirc from cold the blue temp sensor should give a 330 ohm reading. The TPS has to be measured in ohms and should read 1 on closed throttle about 3 ohms on half and nearly 5 on WOT. The crank and cam sensors should both give 90 ohms with the ignition on. Only one i dont no of the top of my head is the AFM, sorry.
cliffybabe
- Powered by Nelly
Dude i thought duffys had pitting issue's not fun
Kedge
Just stripped the block down this afternoon and i'm glad this happened when it did!
The crank sprocket on the chain has about reached its limit of wear, the tips are very sharp and every other tooth has worn very deep, could of ended in a big mess if i'd of run it much longer, engine sounded fine as well!!
