Post
Sun Jan 07, 2007 3:01 pm
nice clean lookin car, a good base to start the modification bug!! first thing you need to do is resize your avatar.
the mtech copy rear spoiler is probably from autotint design or similar does not look too bad IMO.
These are certainly not standard wheels but copies of the BBS design. they look like 14 inch, if you are short of cash get some 14inch bottle tops and swap the tyres over, will look 100% better. a set should be easliy picked up for 50-60quid without tyres, then get rid of those mudflaps and bits and pieces stick to your windows!!
note the rust around the rear light clusters, remove the boot carpet and have a good look (a bit appears to be on the boot lid too) remove the lights ( 8 bolts from the inside) and sand away the rust and repaint before it gets too bad (it will not be visible anyway) and chack around the inside of the sunroof for rust
aside from that looks like you have a nice clean and honest motor!! welcome to the zone!
mrlee
