towing an auto
jcjdavis1
Hi If an auto has been towed a distance will any damage have been done if the diff. was not disconnected?
Gortour
The diff should have no problem at all.
The problem occurs in the auto box. As this is not being 'driven', the oil is not being cooled and circulated, and the gearbox overheats.
Usual rule of thumb is about 40miles max, at 30-40mph tops...
HTH
HTH
bigun
it depends how far you have towed i think its about 30KMH at a certain speed see your handbook it wont damage the diff it will damage the gearbox
bigun
what engine is it your running 2.0/2.5 etc
jcjdavis1
Thanks Gordon the touring I bought had broken-down on the motorway then towed home.I know where it stopped and where it was towed to so the miles are within your post.I was just checking because as you know you fix one thing then another pops up.
I have a 320i 1989 97500mls. I miss wrote the post as it was the gearbox I was worried about.
Extra oil in the autobox is recommended as well, IIRC.
mrLEE30
yes but too late he has already towed it!! but yes if you must tow an auto add 1 litre of extra oil, and drain it out before you use the thing, in fact better to drain the whole fluid and replace with new uncooked stuff.Extra oil in the autobox is recommended as well, IIRC
as for your touring remove the autobox dip stick and smell the oil, it should not smell burnt, and it should be reddish not browninsh.... my advice would be to change the autobox oil anyway, stick a new filter in there at same time, they are not expensive
, but the good news is if it was towed off of a motorway chances are it would have been towed by a recovery company, and they would have been sympathetic to the box (i hope!!)
Probably still a good idea to change it then.
jcjdavis1
Hi I am waiting to put a recon. head on it, once I have it running I will take it to my work and change all the fluids.
mrLEE30
best idea is to throw it in the bin and put a manual in there instead! but if you must keep it i would (as i said) change the auto oil fliter too, takes five mins once the fluid is drained.
(but i think you need some torx drivers)
mrlee
mrlee
jcjdavis1
Hi mrlee I think I will stay with the auto as I drive an auto coach at work and my left knee needs a rest after years of using a clutch.Mechanic at work will have proper tools for the job.Where is the auto oil filter situated and is it a dealer or ecp part. Jim
mrLEE30
thats fine, mine an auto too, ideal for lazy driving.
the filter is in the ATF sump, raise the car, remove the ATF fluid filler/dipstick pipe from the sump and drain the fluid from here, then remove the ATF sump and you will see the filter, remove the filter (as i said you will need Torx drives) and replace, renew the rubber gasket, and filter o ring, then replace and refill there are a few magnets in there too, clean any metal off of these (if there is lots of metal then ask the mechanic or zone advice!!)...not sure about where to get the parts, over here i get them from motorfactors so would imagine ECP or GSF round your way will have. not expensive here, about 20quid.
FYI i change mine around once a year as its cheaper then removing the governers once they become blocked, but its very dusty here, round in your cold damp country i cant imagine dust being an issue so just change it and forget about it!!!
mrlee
mrlee
jcjdavis1
Thanks mrlee, have printed off your post.I take it you live in hot dry country? Jim
mrLEE30
Yep i live in Bahrain!Thanks mrlee, have printed off your post.I take it you live in hot dry country?
