Inspection plate? For what?
OBs
Post Sat Jan 06, 2007 2:44 pm
Can anyone tell me what this is? (Just behind the Drivers seat) It looks like a hole where a inspection plate should sit! A MOT tester got a little carried away with his trusty hammer!
Do you know if you can get replacements or should I just weld a plate over it?
Andy
Post Sat Jan 06, 2007 2:57 pm
Didn't the MOT tester give it back to you?!
Martinaston
Post Sat Jan 06, 2007 2:58 pm
Its a drainage hole for when the shell is dipped during production, i'd be telling the mot guy to fix it. If he gives you a load of shit about it being rusted then ask him why he was using a hammer on a panel.
There is NO nucleus.
OBs
LOL
yea still got it but its got a hole around the edge....
OBs
Post Sat Jan 06, 2007 3:00 pm
Fair dos Ill just plate it up if its not important...
Cheers guys!
Martinaston
Post Sat Jan 06, 2007 3:01 pm
So did he pass it ?
OBs
Post Sat Jan 06, 2007 3:07 pm
Its not out of MOT until April but I was just looking for holes really... Still hunting a leak.
I sort of gave him permission to go 'nuts' but he did get carried away! I might aswell do all the undercarrage in one go! :mad:
Post Sat Jan 06, 2007 3:11 pm
The miracle of modern technology, allowing us all to look into this... :wink:
Martinaston
Rear sunroof drainage pipes, rear window seal (bottom corner) or the seam along around the wheel arch (not fun) happy hunting.
Post Sat Jan 06, 2007 3:23 pm
I've posted a few times about this hole (and it's mate on the other side) in the last few months, in response to questions about water in the back passenger compartment.
The fixing lugs rust away, as they have on this one, and the back gets wet.
Replacements are probably available from BMW, but won't be any use to you, as the shell has rusted where they fit.
Weld solid plates over them. This is what I do when I restore a shell.
OBs
Post Sat Jan 06, 2007 3:39 pm
Cheers Brian! Yea Ill just plate the old boy up....
