Noddy Q....where is the oil filter on an M42?
MrDazzle
Post Fri Jan 05, 2007 6:02 pm
Hi,
I got a new Oil Filter for my iS the other day. Opened the box expecting a balck cylinder-ish shaped piece of metal, only to discover my filter is sans metal, and just a ring shaped piece of corregated paper affair. Either that or someone's put an extremely small air filter in my oil filter box.
I knew these types of filters exist, but didn't know the M42 was fitted with one. So...where is the housing for the filter?
Cheers.
Pal318is
Post Fri Jan 05, 2007 6:07 pm
How's that, it's the round thing :mad: next to the right tube, if that makes sense....Sorry if it don't, my expalnation's can be shite at times..
Pal
Pal
Image[img]http://Image
MrDazzle
Post Fri Jan 05, 2007 6:18 pm
Well I can see the bit you mean either way:wink:
The tubes are coolant in and out lets.
kevin316i
Post Fri Jan 05, 2007 9:09 pm
There are two different filters shown on the ETK for the M42 engine a tall skinny one and a shorter wider one similar to the one fitted to my previous E30 316i. My car has the wider filter that sits in the metal bowl on the right hand side of the engine in the diagram above.
The filter should take up most of the space inside the bowl. The original BMW filters have a metal casing as part of the filter while some aftermarket ones such as the MANN filter have no metal components. Original BMW filters are as cheap as aftermarket ones!
