Just Wondering.... Fuel Gauge Problems
mummy-boo
Post Fri Jan 05, 2007 8:15 pm
Tiny problem, i filled the car up the other day and noticed that at the point of petrol spewing all over my feet - in other words full :mad: - that the gauge was only reading 2/3 full. any ideas as to whats happened??
Thanks.
Hayley xxxx
Hayley xx
"Float like a Cadillac, Sting like a BEEMER!"
marty1979
Post Fri Jan 05, 2007 9:18 pm
It sounds like the sender unit could be the problem. Maybe the sender's stuck, or the gauge could be restricted from passing a certain point?
SPADGE
Post Fri Jan 05, 2007 9:28 pm
How much did you put in it to fill it?
march109
Post Fri Jan 05, 2007 9:31 pm
could be a fualty sender, or some extra resistance in the circuit, a blockage, faulty gauge...
or as you didn't mention where the pertol came from? ie. the filler neck or further down tank could have sprung a leak.
mummy-boo
Post Sat Jan 06, 2007 6:27 pm
the fuel spewing bit was from the filler cap as i'd put that much in.
how did i put in it?? from well past the red (the point where the light should come on) £43 worth. which put the fuel level to the spilling over my feet point.
Hayley xx
