would these fit a 318i 1993 cab
DJ_B4L
would mtech anti roll bars are off a 325i sport 20mm front 14.5mm rear
fit a 318i cab L reg
i will be converting to a 2.5 soon it has discs all around
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
orangecurry
erm the M-techs might be smaller than the ones fitted at the factory...
look up yours on realoem
orangecurry
I was half wrong - the rears left the factory at 12mm, the front is already 20mm
DJ_B4L
i thought the 1.8 didnt come with rear ones fitted?
il check the realoem website in a bit
did the front def come with 20mm ones can any 1 confirm this
also are these the best or are there bigger availabe
orangecurry
Go stick your head under your car
If you want ARBs from BMW, the ones on the 325 cabbie are 21mm (so probably not worth it).
Ask Sal about the best aftermarket ones. Hartge not available anymore, but H&R do some? Be careful what you do, as you might introduce understeer, and we don't want any of that nonsense, do we?
DJ_B4L
nah dont want any problems with it
jus want to make the handling better as its going to be a 2.5 frm a 1.8i
some one told me that the 318i's that have abs it can e added to these, but they dont come with one
DJ_B4L
on real oem it shows that its got a 20mm front one and a 12mm rear
would it make any difference fitting a thicker one on the back?
orangecurry
I thought all cabbies had F&R ARBs - like I said, stick your head under.
Depending on how many miles the car has done, to improve handling you'd be best replacing rubber bushes everywhere, and to help with the extra weight at the front, fit the 51mm front struts - is this a straight swop?
orangecurry
that's what I saidDJ_B4L wrote:on real oem it shows that its got a 20mm front one and a 12mm rear
fitting a 14.5 at the rear might make a difference, but BMW thought that a 12mm was best.................. fit it and let us know
There's a thread somewhere (that Sal started) about suspension and how easy it is to make handling worse by going too stiff oo-er, or introducing understeer by having too thick an ARB? I'll see if I can find it.
orangecurry
DJ_B4L
jus read the above thread says that leave the front as it is and by changing the back will make it handle better
DJ_B4L
i have standard shocks and and 325i lowering springs the car handles great already but need to improve it more
orangecurry
it does, but that wasn't a cabbie, and you are going from 12mm to 14.5mm not 16mm.DJ_B4L wrote:jus read the above thread says that leave the front as it is and by changing the back will make it handle better
But I meant what I said - fit it and replace any rubber bits at the same time, then tell us all about it. Depending on the mileage of the car (??????????) replacing the rubber will be the best improvement.
DJ_B4L
yeh i see if i can get hold of a 16mm one might aswel jus fit a bigger one than gettin a 14.5
jus do it in one go.
