Injectors
win
Post Thu Jan 04, 2007 3:08 pm
i've adjusted my valve clearances on my 325 and the car is running well now. I've still got a clicking sort of tappety sound whenever the accelerator is pressed. I beleive it may well be the injectors as when i switch the engine off you don't hear any noise following on. How easy is it to change the injectors because the sound is pretty annoying.
ANy help greatly appreciated.
Win
Martinaston
Post Thu Jan 04, 2007 6:47 pm
There aesy to change, its the cost of new ones thats the killer.
There is NO nucleus.
Ant
Retired Team Member
Retired Team Member
Post Thu Jan 04, 2007 7:35 pm
and the new ones will be just as noisy dude
you dont hear the sound on later BMW's( ford/vw etc etc) because there is an insulated plastic cover over them, muffling the noise.
only way to make them quiet is add an aftermarket ECU and alter the inj PWM til you can bear the noise, expensive fix though 8O
Dont buy new ones, its dead £Â£Ã‚£ dude.
most common noise other tha the injectors is a blowing exhaust manifold gasket, check that too M8 :thumb:
Post Thu Jan 04, 2007 7:44 pm
Wouldnt cleaning quieten the noise? If im right its because theyre partially blocked that theyre tappety?
Is ultra sonic cleaning all its cracked up to be or are they just as well left in carb cleaner overnight?
win
Post Thu Jan 04, 2007 9:31 pm
Ant, cheers for the advice but can i ask you a question? my car is a 1986 325sport, when these cars were new did they still sound like that or is it due to the age of the car. It has 163000 miles on the clock and its got good service history, the first 12 years is all bmw service history plus loads of receipts.
And Dan, how would i go about cleaning them and what would i use?
Win
Post Thu Jan 04, 2007 10:38 pm
You can soak them in carb cleaner, ive heard of ultrasonic cleaning but im not clued up on it :?
Ant
Retired Team Member
Retired Team Member
Post Thu Jan 04, 2007 11:42 pm
Ultrasonic cleaning is effective, but will not result in any real change in the noise.
I put Brand new , boxed,sealed Ford motorsport injectors into my car( 42 lbs/hr with aftermarket ECU and turbo BTW.), they sound the same, they should, they work in the same way and thats the bottom line 8)
if the noise is annoying inside the cabin only, take the steering wheel badge out and slap a blob of blu-tac or mastic into the hole in the steering shaft, always drops in cabin noise by 25%
iirc, these were as noisy from new, indeed run a modern BMW ( petrol ) with the engine covers removed, things haven't changed :lol:
win
Post Fri Jan 05, 2007 8:39 am
How would blu tac help reduce the noise? and also i had the manifold gasket done about a month ago, but i did'nt change the downpipe gasket would this make any difference
Chris-W
Post Fri Jan 05, 2007 9:07 am
The steering column is hollow, noise runs up through it.
