If i fit them in the correct position they will cause too much castor angle, as my car is running standard sport suspension the wheels will hit the front of the arch so i was thinking of fitting them at 45 degrees so it will give me half as much castor.
Has anyone tried it ? Will they last or twist the bush in the lollypop ?
Or even cause problems with the camber ?
Any help appreciated
Cheers.
M3 front bushes
Martinaston
There is NO nucleus.
Demlotcrew
i have them at the correct settings and nothing rubs.
Your car might have had a front ender?
Andrew
Andrew
Andy335Touring
Mine rubs a tad on the liner on full lock with those
Demlotcrew
Guys im rinning 225s on the front and no rubbing!
You can move the lower undertray forward quite a bit so what im getting at is that you should try and adjust that if you can be arsed (but the M3 bushes are the bolox)
Andrew
Andrew
Martinaston
Mines got the standard ones on at the minuet and only rubs on full lock when i'm in reverse, its not good considering the direction of the tyre because if it catches then its bye bye undertray.
If i ever get around to changing the engine and adding the aircon the car will sit a bit lower, so i'll have a bit more room to play with, but i have a feeling the M3 bushes in the right place will still be too far forward to clear so i'm wondering what it would be like with 1/8th of a twist on them
Has anyone tried it with the poly adjustable ones ?
E30Adam
I've had loads of different wheels on my car as many of you know and also have the M3 eccentric bushes. I don't get any rubbing at all and the improvement is massive.
If you've got rubbing then there's a problem with the car or they're not the right wheels!!
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
