what do you think.......
kam-325i
Just been on the old bmwe30.net forum, and found a topic on this little number. One of the user's has fitted one and, with arse dyno, says that there is a noticable difference.....
What do you think....
http://www.millerperformancecars.com/m20maf.html
kam-325i
At current exhange rates, it works out at £132 !!!
BIGJO
I wonder if it's any good?
kam-325i
Well, they have thought about it, as it is not just a MAF, but you also get a new ECU chip that is mapped to take advantage of the MAF.
It should be better than just a MAF conversion on its own.........?
BIGJO
Seems like a reasonable price, but wonder if it actually makes much difference?
Regards, BJ.
Regards, BJ.
d6dph
Would the chip not be mapped for the lower octane fuel they run in the states? Bargain if it works tho
liam012
look at the price cut...
there is no doubt if its mapped for the right octane fuel its a good bolt on mod
but if you see the original price - they have realised that poeple would rather buy a complete standalone management sytem that you can map as you like for each mod you make than throw that sort of serious money at a once of not rtemappable mod.
it is still £100+ mod and if i had a choice between standalone ecu or this kit with an itg filter and a chip - i know what i'd be getting....
Looks great, but a shame it doesn't mention which size of M20 it's designed for.
kam-325i
Miller will supply your a Map for your engine, They will also change the map to to suit your fuel rating and change the rev limit if requested.
Heres the topic on BEN
http://forums.bmwe30.net/read.php?5,9902
Sounds good, if only for the sharper throttle response and lowering of the revs at which the 'real power' kicks in.
johnono
seem positive kav
if its as simple as it looks on the walkthrough, then i´d go for it fella
Anyone ordered one yet? They quoted me $17 for shipping...not so bad. I'm tempted
kam-325i
wrong side of xmas for me........but i am seriously considing it......
I am thinking of getting the whole shabang......The MAF with chip and the software.........
With other MAF conversions, its the MAF that is altered to send out a signal that is the same as the AFM so that the ECU can read it, But this one does not. Instead, the MAF is left alone and you fit the chip that can read the MAF signals, and the chip is programmable, so you can tweak it till your hearts content.....
God....i sound like a salesman !!!!
d6dph
Surely it can't be that easy?
Group buy anyone?
Group buy anyone?
kam-325i
I know what you mean...I keep waiting for the catch.......
They dont even make wild claims about the perfomance gains......
d6dph
hmmmm, where's that damn credit card!
Seriously tempted but just have that niggling feeling I'm p!ssing money up the wall?
Well, I've bitten the bullet and bought one...a little Xmas pressie for myself you understand
(My car currently has some kangarooing at low speed, so with a bit of luck getting shot of that nasty flappy AFM thing should help...)
It doesn't cost any extra to specify the 7,000rpm rev limit and UK-spec fuel
Falkster
Christ thats a bargain!!320iSE wrote:Anyone ordered one yet? They quoted me $17 for shipping...not so bad. I'm tempted
Might be worth a go....not sure if they'll do it for the s14 though
Finally got the installation of the Miller MAF completed today...and the results are very pleasing, with far smoother/more sensitive and faster throttle response with *no kangarooing!!* You can trickle the car along in 5th gear right down to idle speed (700rpm) and pull away cleanly. It was quite easy to get >30mpg. Revs smoothly up to the 6,500rpm rev limit that the standard chip allows (Miller are sending the 7,000rpm chip I specified separately).
I opted for a more 'sympathetic' installation than those of Miller's official instructions, which avoid the need to cut any of the existing wiring loom; this involves the use of the spare socket next to the fuel pump relay to provide an ignition switched +12V to the MAF. So it can all be easily reverted to standard if necessary.
All in, I'd say it's a very worthwhile mod
I've put up some pics here: http://uk.pg.photos.yahoo.com/ph/mtjhun ... e2&.src=ph
Andy335Touring
Cool, get it on a RR to see how well it's doing
Ant
- Retired Team Member
better still, come see me and I'll plot the AFR's !
still seems a little to good to be true though, not pi$$ing on anyones fire here though you understand.
Email FTW
Andy335Touring
Can you check mine tooAnt wrote:better still, come see me and I'll plot the AFR's !
What are the AFR's Ant? I might be up for it if I know what they are!
Andy335Touring
Air fuel ratio's
You're welcome to test the AFRs if you like...might be better to wait 'til I get the 7,000rpm chip in though? (Hopefully should be delivered sometime this month).
Ant
thats a quote off their own site, using Matt G's touring as an example, they are not taking the pi$$ with those claims, alittle high yes, but within what is achieveableyou can expect 10 HP and 18 lb/ft.
Maurice, let me have a gander .....
Email FTW
Jimbob
Ant's thumbs are twiddling at an excessive rate now! LOL
This sounds like a great mod, and if I still had my 2.7 M20 I would most definately purchase this kit.
OK, Ant. Just let me know when & where...
Dan318-is
320ise well done for taking the plunge get it on a rolling road or on ants wideband and see if its doing any good.
they are making an m42 one soon, i feel some more university loan abuse coming!
jaistanley
I'd jump at the chance to have them checked fella, especially after plugging in a chip..
Jai
Jai
Yeah, makes sense. BTW, your link for parts wanted doesn't work!
Miller sent through the 7,000rpm rev limit chip (free of charge, which was very nice of them!!
) so I installed it today - works well, nice and smooth all the way. I have to say, I'm impressed with the MAF kit, and Miller's customer service.
