differential & gearbox
suzie650
Post Fri Dec 22, 2006 10:47 pm
Hi zoners!
I wanted some info about the differences between a 5 speed and a 6 speed gearbox for an S50B32 swap. Does it make any big difference? I thought the 6 speed might be easier to source (directly with the engine) and slightly more painful to fit (custom mounts and propshaft, if I'm right?). But is it worth the hassle?
And what diff do you use to put the phat power to the road? 3.2? 3.4? Could you also tell me about the average costs for these?
Thanks!
Seb
Post Fri Dec 22, 2006 11:14 pm
From what I've read, the six speed is big, heavy, expensive and unnecessary.
suzie650
Post Thu Jan 04, 2007 2:23 pm
Hum...
Did I badly overestimate the number of these swaps on the forum, or does the information stand elsewhere :?: :?: :?:
Gunni
Post Thu Jan 04, 2007 4:26 pm
5 speed lover the 3.25, I had it and it was great
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
e30_Turbo
Boost Junkie
Post Thu Jan 04, 2007 4:50 pm
suzie650 wrote:Hum...
There are two evo engined e30's on the zone, Buster and Ian332i.
Ians conversion is the longest finished and Busters is a few months old now.
IIRC Alex, (turbobrown) has a 3.2 evo lump in his care but I don't think it's gonna end up in a e30. Dips has a V12 e30 with the 6 speed box, he maybe able to help you.
HTH, Mark.
Post Thu Jan 04, 2007 5:03 pm
Depends on your driving really. I have an M50B25/box with a 3.25 diff, for me the gearing is too high at cruising speeds, although the acceleration is nice :)
At 3000 rpm im doing an indicated 70mph which in reality is more like 65mph, ive bought an E46 6 speed box with 0.83 overdrive 6th which should bring the rpm down 500 revs
As I understand it, the only modding needed to fit the E36 6 speed is the prop
suzie650
Post Thu Jan 04, 2007 5:32 pm
Thanks for all that information!!!
Post Thu Jan 04, 2007 6:03 pm
And a custom mount
Plus it isnt as strong and they cant easily be rebuilt
Post Thu Jan 04, 2007 6:21 pm
Oh yes, custom mount, just like I need :-x
