525i gearbox
kempo_perth
Post Thu Jan 04, 2007 5:49 pm
iv got a 525i and hopin 2 put the engine in my 3series touring was jst wonderin if the gear box will fit easy
Martinaston
Post Thu Jan 04, 2007 6:45 pm
Find the gearbox number then do a parts search on the realoem website and it will list all the models its fitted to.
As long as its an M20 engine the box should be ok, its just the ratios that you have to worry about.
There is NO nucleus.
SPADGE
Post Thu Jan 04, 2007 6:47 pm
I suspect the output flange on the e34 box may be bigger than the e30 prop needs but you may be able to just swop this over?
