central locking
markevans
can some one help my central locking soleniods have stuck open and wont move, have had proplems with my central locking unit but got new one now but still the solenoids will not move ,have taken them out of doors is ther a way to free them or do i need to get new ones
HartgeH27
Hello Mark,
Welcome m8 and if you do a search via the search tool you will find many articles which will help you.
If you get stuck then shout.
Iain
Iain
smithy318i
you probably need new ones.
since your c/l relay was melted, it probably also fried all of the servo's
markevans
eko
- Old timer
If youve replaced the relay and the servos than chances are its the `Red/Black` wire on the drivers door!markevans wrote:Brianmoooore wrote:I'd put money on it!smithy318i wrote:
since your c/l relay was melted, it probably also fried all of the servo'syse they have put new ones on doors locked via boot but would not open had to open each door indiv, same on drivers door any ideas
Do a search using these key words-Red/Black,Brianmoore.
Gets covered about 10 times a month so youll soon find the article explaining what to do
markevans
cheers will do thankseko wrote:If youve replaced the relay and the servos than chances are its the `Red/Black` wire on the drivers door!markevans wrote:Brianmoooore wrote:I'd put money on it!yse they have put new ones on doors locked via boot but would not open had to open each door indiv, same on drivers door any ideas
