Hi there. I have had a 320 touring for less than a year and in that time have had reoccuring overheating problems. I had a new fan clutch fitted and then the water pump fell apart and had to be replaced. It is sitting in the middle of the temperature guage most of the time but is still overheating in traffic the odd time. Is there anything else I should do?
Overheating issue
marty1979
Hi there mate. It could be a number of things causing overheating. If you have had a new fan clutch and water pump then you can start looking at the thermostat or maybe even an air lock, or even worse it could be a buggered head gasket. How does the oil look, is there any white gunky stuff on the oil filler cap, or any oil in the coolant?
Padzer
Hi. Yeah hope is isn't the head gasket. I'll have a look at the oil cap and in the expansion tank.
The fact that the temperature is regulated when the car is running and not in traffic, does this indicate anything more specific?
cheers
cheers
marty1979
Well if you hadn't have replaced the fan clutch then that's the first thing I would thought of being the problem. Of course it might still be faulty, from what I've read on here, the best way to diagnose a faulty fan is to roll up a newspaper and jam it into the fan when the engines running. If the paper gets ripped up then the fan's ok, if the fan stops then there's your problem. If the fan does turn out to be ok then I would look at the thermostat, unless you find reason to believe the head gasket has gone, then that would be the cause.
Padzer
thanks for you help I'll try that...
Padzer
Tried the rolled up newspaper in the fan and it stopped it within seconds. So i'll be back to the garage to see what the story is since I've only recently had the fan clutch replaced.
P
P
