Ages to start because of wrong CO setting?
liam012
Post Wed Jan 03, 2007 11:02 pm
i read/misread in the autodata last night that my CO reading should be 0.5 max (this turned out to be wrong)
so set it at 0.5 (which involved tightening the idle co screw considerably) and drove home
however casr very difficult to start this morning (tried to idle at 600 for first 4-5 seconds but woke up then and hit 900 rock solid.
Went for drive about 1 hour long , pull in and go to shop return to car which is still quite hot and no start - ended up coming back later planning to tow but with a boot full of tools i decided to get the spanner in before admitting defeat - cranked - still no start , getting good spark - check over plugs and they are just flooded with petrol - something is making the mixture far to rich? (though the car is stone cold so perhaps its not the blue sensor which i was suspecting when car wouldnt start from warm. so to get it going i undid the hose for the afm and allowed a gap of a few mm to appear so the throttle body could get good suck of air and she started - i remembered reading last week that 1.4 was the CO and thought maybe i had tightened up the idle mix so much that there was just no air to be sucked in? i remebered workiong on the Co machine last night s i have re adjusted the co idle screwto where ' i think' 1.4 is and well check at the weekend.
i wont know till tomorow when i try to start it normally without disconnecting the intake boot but i think it was air starvation? is that possible?
liam012
Post Thu Jan 04, 2007 1:30 pm
started normally from cood and warm on the button - yeehah!
so i am guessing i just strtangled the car witht the over tight CO idle screw.....
Templ8e30
Post Thu Jan 04, 2007 5:10 pm
Low CO could do that.
Glad you sorted it :D
Cheers,
Iain T
2007 Mazda 6 2.0 estate
